Question about Dell XPS M1530 Notebook
How do I boot to windows or disable bitlocker?
DellCares
  • Official Brand Answer
  • 560 Answers
Anonymous,
Steps to Turn On/Off BitLocker:
Click the Start button to view the Start Menu and then choose the Control Panel option.
The Control Panel window opens up.
Now click the System and Security link from this window.
The System and Security section of Control Panel opens up and you can see the direct link for the BitLocker Drive Encryption.
Click on the BitLocker Drive Encryption and a new window opens up.
By default the BitLocker Drive Encryption is Off for the Hard Disk Drive. Click Turn On BitLocker. If a compatible Trusted Platform Module.
Note: To use BitLocker Drive Encryption, your computer has to meet certain hardware requirements.
Otherwise, this opens the BitLocker setup wizard. Follow the instructions in the wizard. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
Click Turn Off BitLocker. This opens the BitLocker Drive Encryption dialog box. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Posted on Jul 08, 2014
1helpful
3answers
Dell latitude laptop locked out with it asking for bitlocker password which I Don't have and i can't access my computer now
If you don't know the bitlocker password, forget getting access to your computer. Take out the hard drive encrypted by bitlocker, and install a new hard drive. Reinstall operating system on the replaced hard drive.
It will be a new installation.
How to remove bitlocket from my laptop...it appears on one of my apps and also the avast shortcut...I tried to remove the app and installed it again but its still there
Go to Start > Control Panel
Right click on Bit Locker
To turn off or temporarily disable BitLocker
To decrypt the drive, click Decrypt the volume. To temporarily disable BitLocker, click Disable BitLocker Drive Encryption.
Feb 04, 2015 • Cell Phones
I have encrypted my local disk using bitlocker encryption and now it shows Local Disk(D:) is not accessible Access is denied and when i right click it was not showing security tab. please help me
Try This:
Before you start
  • You must be logged on as an administrator.
  • The volume must be encrypted.
To turn off BitLocker Drive Encryption
  1. Click Start, click Control Panel, click Security, and then click BitLocker Drive Encryption.
  2. From the BitLocker Drive Encryption page, find the volume on which you want BitLocker Drive Encryption turned off, and click Turn Off BitLocker Drive Encryption.
  3. From the What level of decryption do you want dialog box, click either Disable BitLocker Drive Encryption or Decrypt the volume as needed.
    By completing this procedure, you have either disabled BitLocker or decrypted the operating system volume.
    Good Luck!!
2answers
Why does my netbook password not work? It says encrypted and can't long in to my netbook.
What operating system are you using? You might have to reinstall your operating system since you might have a virus
1helpful
How do I disable microsoft bit locker from the start buttom bottom left of desktop page, everytime i turn on the computer i've to statr about -10 times before it will start, i hit the home button which i...
Copy and paste the following link into your internet browser:
http://www.techtalkz.com/windows-7/515981-enable-disable-bitlocker-drive-encryption-windows-7-a.html
This is for Windows 7 OS.
2answers
I'm at my nephews, and he has been on my x61, haven't got a clue what he has done, but now locked out and reading 'windows bitlocker drive encryption pin entry' I haven't got any codes or passwords with...
Sounds as if he may have activated 'bitlocker' on your drive. Ask him for the pin code he used and if you get in disable 'bitlocker'. Highlight the drive in My Computer>right click and select turn off bitlocker.
I hope he remembers the pin code he used!
Same proble, MS BitLocker is error message.
Bitlocker is available for Vista Business, Enterprise and Ultimate. This gives more security to your data files against unauthorized access. Once bitlocker detects theres a major change of hardware, such as master boot record, motherboard replacememt and such, it thinks that the hard drive is moved to another computer. Usually, bitlocker encryption can be disabled using the USB drive that was used to store the codes for decryption.
I won't to Know if I can use bitlocker on my laptop
If the TPM is not enabled in the Bios,Then you can use Bitlocker.
If it is enabled,You will need to check with Toshiba for compatibility issues or disable TPM
I run it on mine and it works fine.
Dell XPS M1530 Notebook Logo
Ekse
Mandeep  Singh
Mandeep Singh
Michael Thomas
Michael Thomas
