SOURCE: Everstar MPM1-10CR-BB6
The directions have the steps to take when a "P1" error is flashing.
1) Remove the plug (the upper black plug not the lower) and attach the included drain hose.
2) Put a bucket under the hose.
3) Press the TURBO button for MORE THAN THREE SECONDS. The WATER INDICATOR will begin flashing telling the user that the FORCED WATER DRAINAGE feature is activated. You will even hear a little whirring noise.
4) Wait until the WATER INDICATOR stops flashing and no more water is flowing out of the drainage tube.
5) After the water is finished flowing, make sure that you FASTEN the DRAIN PLUG. Of course, failure to do this will flood the area.
6) The unit should now work.
You can also move the unit somewhere that you can remove the plug and let the water flow freely (you do not need to have it plugged in for this method) and once the water is finished, replace the plug and fire it up. It should then work correctly. It's also mentioned that the water should be drained quite often to prevent corrosion. I do it every few months and of course when winter approaches.
I like this air conditioner and have had really nice luck with it. A little loud but who cares. That's why there are SUBTITLES on the television.
Hope this helped.
RoC
SOURCE: need owners manual for Everstar Portable AC MPM1-10CR-BB6
Here's the 34 page manual from Danby Canadian website. =>
http://www.danby.ca/cms/uploads/products/en_manual/DPAC8020.pdf
Please leave feedback. Thanks.
Needed the manual to clarify a P1 error message. Figured how to fix the error P1 on my own. there are two drains on the unit, one is always open as an overflow drip, the other at bottom of unit has a plug. I opened the plug at the bottom of the unit, drained the water, and the P1 error code cleared.
SOURCE: Everstar mpm1-10cr-bb6, I need parts or am I SOL
www.supportuscenter.com/pilot.asp They have a few part here it took me awhile to find this!!!
