Question about HP LaserJet P2055d Printer
Jam in cartridge area - HP LaserJet P2055d Printer
Eric Engel
    Scholar:
    New Friend:
  • 122 Answers
This problem seems to happen with remanned toner cartridges. The link below provides the solution:
http://cincinnatiprinterrepair.com/service-call-of-the-week/50-hp-laserjet-m400-jams
Posted on Feb 11, 2015
Momed I. S. Dalsuco
    New Friend:
  • 83 Answers
Hi, remove the toner cartridge out of the printer then remove the jammed paper.
Posted on Jul 15, 2014
Hp LaserJet Pro 400 paper jam in cartridge area
Clean all of the rubber feeders with alcohol/rubber restorer in the paper path of printer.
Sep 14, 2016 | HP Laserjet Pro 400 Mfp M425dn...
JAM IN CARTRIDGE AREA
We have found this error is not related to the cartridge area. We found that the exit flag spring in the back of the fuser is wound to loosely. Carefully take the spring while it's in place in turn it one full turn tighter. You will need a hook for this procedure or a bent paperclip. Resecure the end of the spring and bend the tip so it does not unwind. For good measure place a small amount of glue on the end of the spring. Our customer has about 100 of these machines in 10 of those were giving the jam and cartridge area message. After performing this procedure on all 10 we never had another issue with the machine
Nov 27, 2011 | HP LaserJet P2055d Printer
Jam cartrige Area
Clear jams from the print-cartridge area
1. Open the print-cartridge door, and remove the print cartridge.
Figure 18: removing print cartridge
2. With both hands, grasp the side of the media that is most visible (this includes the middle), and carefully pull it free from the product.
Figure 19: removing jammed media
3. Replace the print cartridge and close the print-cartridge door.
Figure 20: reinstalling the print cartridge
For any other Jam types Visit the following link : HP Lasterjet M1522
Regards,
Shrey
May 30, 2011 | HP LaserJet M1522nf Multifunction Printer...
I have a problem. When I turn on my printer, the first symbol from top constantly blinks and it doesn't print anything. How can I solve this issue?
Welcome to FixYa!
If the first symbol on the top is constantly blinking as shown in the picture below, It means that a paper or a foreign object has jammed your printer.
Jam can occur in 3 areas. Please refer to the image below.
1. Internal Areas
2. Input Trays
3. The Output Bins
To clear the jam, turn the printer off and disconnect the power cord. Be careful not to tear the paper in case of a paper jam. If a small piece of paper remains in the printer, it could cause additional paper jam.
Let's clear out the Internal Areas first. Push the button to open the print-cartridge door, and then remove the print cartridge. To prevent damage, do not expose the print cartridge to light. Cover it with a piece of paper. Please refer to the image below.
If jammed paper is visible, grasp it with both hands and slowly pull it out of the printer. Please refer to the image below.
If no paper was jammed inside the print-cartridge door, open the Output Bin or the back door
of the printer. To avoid damaging the printer, do not attempt to clear a jam in the top output bin by pulling the paper straight out.
Again, if jammed paper is visible, grasp it with both hands and slowly pull it out of the printer.
If no paper or foreign object is visible, close the back door of the printer.
Next, let's take a look at the Input Tray. (We have already taken out the print cartridge.)
Lift the Tray 1 roller cover, grasp the jammed paper or foreign object, and slowly pull it out of the printer. Please refer to the image below.
If no jammed paper is or foreign object is visible, open Tray 2 and see if a paper is visible. Again remove it slowly with both hands. Please refer to the image below.
Close Tray 2.
If no jammed paper is visible in the second tray area, pull down the upper media guide (we have already taken out the print cartridge). With both hands, grasp the jammed paper and slowly pull it out of the printer. Please refer to the image below.
Close the upper media guide and return back the print cartridge. Please refer to the image below.
These steps should clear out any jams that you are experiencing.
Connect back the power cord again and turn on your printer. You should be able to print now.
Thanks for using FixYa. Keep me posted.
Jas247
Mar 03, 2011 | HP LaserJet Black-and-White Laser Printer
The printer says that there is a cartridge jam and it will not print.
Does it say "cartridge jam" or "jam in cartridge area"?
If it is the latter open the door and remove the jam.
Then press the SELECT button to continue.
Feb 26, 2011 | HP Color LaserJet 2600n Printer
Jam in top cover area
Replace your paper pickups and set your paper tray setting correct, both in the tray and the settings menu. That should help you out. The part# for paper-pickups is RF5-3739.
Mar 17, 2009 | HP LaserJet 4600dn Color Printer
Paper jam
Hi usually paper jam at paper input area a or transfor section(photo drum area or fuser unit area, so you may try:
1) take out paper tray and open the cover that you can change toner cartridge there (see manual) looking for any paper inside paper input area or around the cartridge, then take out jam paper.
2) open fuser unit at paper output area ckick a locker at somewhere (see maanual) looking for any paper jam
Dec 22, 2008 | Canon imageRUNNER 1310 Printer
Cartridge stalled
change the printer settings on your ms office.
Sep 26, 2008 | HP Photosmart 8050 InkJet Printer
Hp Officejet 6310 All-in-one paper jam
Here's a video that shows how to clear a jam on this printer.
Apr 08, 2008 | HP Officejet 6310 All-In-One InkJet...
HP LaserJet P2055d Printer Logo
738 people viewed this question
Ekse
efs_perpends
efs_perpends
