SOURCE: BATTERY FOR THIS MODLE WILL NOT HOLD A CHARGE WHY?
Try a differnt battery. Some batteries are bad right off the shelf. Keep the camera out of direct sunlight as this seems to drain my batteries faster than anything. Write back with more details of your problem if this doesn't help.
SOURCE: Worthless batteries won't last DGW-100
Try rechargeable batteries if your are using AAA. Some cameras just stop working with the AA one-use batteries. If you have a lithium or other specialty battery, try getting another battery. Your battery may need to be replaced.
SOURCE: I HAVE A MOULTIE DGW-100 AND THE BATTERY SAYS LOW
never had much luck with 6v lantern bats...drain too fast.Moultrie estimates 20 day life...less if you're getting a lot of events...I recommend the "equivelent"..6v, 4AH or higher rating...
The SD card may be "locked". Check that small switch on side of card is pushed toward contact strips.
ron
