Bosch 24 in. SHU43 Built-in Dishwasher Logo
Question about Bosch 24 in. SHU43 Built-in Dishwasher
Worth repairing a 12 year old neff dishwasher's circuit board professionally?
Neff S5943XOGB slimline dishwasher. Running on what sounds like a wash cycle for 2/3/4 hours, not heating, or emptying properly until you open door and reset machine. Then it empties and finishes itself.
1 Related Answer
Anonymous
  • 145 Answers
SOURCE: My dishwasher has been running for 4 hours!
The long cycle is caused by the heater not heating the water or not having enough water in it to heat. It is normally a slow fill valve in the unit. The best way to check is to start a cycle and let it fill to see how much water is in it. If you add a little water to it and it pumps better you will know you have a water supply problem.
Posted on Apr 23, 2008
My dishwasher takes water but does not start to wash it pumps the water out and takes new water and that's going forever
SOUNDS LIKE THOSE LITTLE ROACHES GOT INTO THE CIRCUIT BOARD AND FRIED IT.
MAIN CIRCUIT BOARD HAS BEEN SHORTED OUT
1helpful
Neff Integrated slimline - Programme does not complete.
IT SOUNDS AS THOUGH ITS NOT HEATING DETERGENT AND RINSE AID INTRODUCED INTO COLD WATER WILL GENERATE A LOT OF FOAM,IS APPLIANCE WARM INSIDE AT END OF CYCLE?OR IT COULD BE TOO MUCH RINSE AID IF IT IS FILLED WITH RINSE AID AND YOU ARE USING A TABLET WITH RINSE AID COMBINED IT WILL HAVE TOO MUCH TO USE IN ONE WASH.
1helpful
Neff s5946 slimline built in dishwasher. Fills with water, clonking sound in pipe and does not register on programme, although pump working.
if you only hear the clunking sound while the dishwasher is filling then the inlet valve is bad.. i would replace it because if it fails completely you could possibly have a flood..
1helpful
NEFF Dishwasher Model 5623.25 keeps sticking during running
At what point in the programme does it stick, i.e. is it washing or rinsing or draining, does the water get hot?
Hi I have a neff s5459x1/21 dishwasher that will not drain. I had a tech out today that charged us $143 and could not diagnose the fault he said it was either a board or a pump. Wash cycles work fine...
Dear friend,
ngfam at you service!
Why did you pay him more than a $75 service call if he can't and didn't fix anything!!!
Tell him to fix it and credit the 148 towards the job!!!!
WOWWWWWWWWWWWWWW
If the dishwasher is 10 years or older its not worth investing money to fix it! The new ones are mush more efficient and clean better!
Either way this is a service problem to remedy!
Below I gave you a nation wide service thats very good!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Neff H5642 1000 Watt Microwave
Sounds like the Magnetron may have collapsed. Probably not worth repairing. Check for burnt/browned components on circuit board/s. Burnt wires, insect or ant damage or soiling. Magnetron is the large-ish square metal object with lots of heat-sink fins on it. Check for discolouration. If nothing obvious, it's probably stuffed, If something is obvious, it's still stuffed, but it may be repairable.:::Spiceweasel.au
Neff slimline dishwasher type S5946
hi there sounds like your wash pump has burnt out
Neff S5555 - empties water but stuck in draining mode.
if this machine uses an electrical-mechanical timer with cam switches, the try oiling the shaft bushings both for the timer motor and cams-the timer may be getting stuck because of dry or corroded bushings
Top Bosch Dishwashers Experts
W.L.
mark warfield
mark warfield
David Shaub
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
