Question about Indesit 18 in. D41 Slim-Line Free-standing Dishwasher
Indesit idl 42 2&4 lights flash - Indesit 18 in. D41 Slim-Line Free-standing Dishwasher
4 Related Answers
Anonymous
SOURCE: Indesit IDL 40 Slimline flashing lights
I have the same problem as well. I have tried adding salt, but I still get the flashing lights.
Does anyone have a solution?
Posted on Mar 01, 2008
Anonymous
  • 679 Answers
SOURCE: flashing green light on my indesit dishwasher
Put some towels dowm and tip the dishwasher over to one side about 45 degrees, if water pours out of the base it means that the dishwasher is in "flood mode" and you have a leak into the base that will need resolving.
Thanks
Posted on Feb 08, 2009
Anonymous
SOURCE: Indesit IDL 50 Dishwasher
Had a similar problem (flashing lights 1 and 2). Drained the machine by diconnecting the outlet hose and using a shallow bowl on the floor. Removed and cleaned filters. Forced clean water through by using a garden hose pipe(you can only do this one way, you cannot force water down the outlet pipe). Removed and cleaned the pump (you have to do this from under the machine but easy enough). Finally ensuring the waste trap under the sink was clear. Bingo!! No parts, no expensive engineer.
Posted on Oct 06, 2009
John Bowen
  • 361 Answers
SOURCE: Indesit IDL40 lights & 4 flashing
First thing I did was to find the information I needed from where it didnt cost me. Then I decided, luckily for you that I wouldnt charge you for how it was fixed. By removing the four screws on the top part of the door and tilting the control panel down to remove it, you will see a black wire that is connected to a thermostat that should be clipped onto the inner metal panel (down and to the right) replace it in its clip and secure it with a zip tie. If this doesnt cure the problem then you will need to check the heater element because its probably blown it due to overheating, last but not least, if the element is in good condition then its got to be the PCB (part number for the Indesit IDL40UK is C00142139 approx £50) that is on the panel you removed to replace the thermostat. It is possible to repair the PCB and the fault is probably the 12v 10a relay and if your confident enough can be obtained from Maplins who do 2 possible replcements with thi same footprint (numbers JM67X and YX97F approx £2). I gleened this information from a number of sources and I thank them for it all, This as far as I can tell is all it can be and its nothing to do with no salt or rinse aid, and my machine is back up and running. I hope this helps others that have lights 2 & 4 flashing and want an answer.
Posted on Mar 14, 2010
Our dishwasher idl 40 indesit has 1 and 3 flashing lights on the panel seems to be a problem
I have had this problem also and no longer take anything apart take out the filter plate pour boiling water into the well leave for 20 mins put on a 25 min fast wash and hey presto works every time. Mine seems to block up about every 4 weeks and the lights come on but this solution always works
Mar 06, 2012 | Indesit 18 in. D41 Slim-Line Free-standing...
Flashing green light on my indesit dishwasher
Thanks
Dec 05, 2008 | Indesit 24 in. D61 Free-standing...
Indesit WIDL 102
almost certainly a new module and eprom. these modules have given a lot of problems.
not really worth doing
Jun 25, 2008 | Indesit W 123 Front Load Washer
Jun 04, 2008 | Indesit 24 in. DE73 Evolution...
IDL 700
A10 2 & 4 Heating element Open circuit heater
info from idl service manuall
Feb 29, 2008 | Indesit 24 in. IDL700 Built-In Dishwasher
the problem you have got with the flashing lights is that its the rinse aid or in need of more salt, hope thats sorts it for you
Dec 12, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit IDL 530 Dishwasher Prewash and Drying Light flashing
Ours was doing this and it was because there was water leaking into the base because a crocodile clip had come off
Oct 22, 2007 | Dishwashers
Indesit 18 in. D41 Slim-Line Free-standing Dishwasher Logo
Top Indesit Dishwashers Experts
Paul Bade
NOEL
NOEL
Ngoro
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
