Question about Toshiba 36A50 36" TV
Rca 27v412t tv picture only in middle of sceen
    Top Expert:
  • Toshiba Master
  • 76,352 Answers
It is the fault with some components related with its horizontal scan output section circuit. Just check the circuit part; and check the components I've marked in red here by its horizontal scan output circuit. Beware; you're going to touch the most dangerous part of its circuit. Keep it in mind always.
rca 27v412t tv picture only in  middle of  sceen - 24780559-dmive0z32bcpzrsafcaw1enm-4-0.jpg If you wish to see the circuit diagram in full; visit
http://schematicscom.blogspot.com/
Posted on Aug 18, 2016
RCA Model 27V412T Trying to fix the screen size. The edges are cut off
When the picture gets smaller that means the high voltage being applied to the picture tube is failing. The flyback transformer and the horizontal output transistor are the likely parts that fail. Power supply capacitors that have domed tops are suspect too. Parts and labor for a TV that old may surpass the price of a new TV.
Sep 08, 2016 | RCA Televison & Video
My RCA 27V412T TV turns the screen red
Can you see a picture at all or is it completely bright red? Is there sound?
Dec 29, 2012 | RCA 27V520T 27" TV
Im looking for the manual for my RCA 27V412T
You can view or save your manual from this site to view in PDF or print if so desried.
http://tv.manualsonline.com/manuals/mfg/rca/27v412t.html?idRes=11396722
Apr 02, 2012 | RCA Televison & Video
Rca 27v412t has sound but no picture. what can i do
Are you technically inclined ? If you are then you may want to check for cold solder connections on your driver transformer.
Dec 16, 2009 | RCA 27V520T 27" TV
TV turns on and off while watching.
re solder the Electronic semiconductor , IC Specialy in power supply side. cold solder might the cause.
Jun 07, 2009 | RCA 27V520T 27" TV
RCA 27V412T
check your tv's power cable inside the tv. make sure its not frayed. also take the batteries out the remote, it could be turning off the tv.
Dec 29, 2008 | Televison & Video
Fix TV
I have a sony i have picture but its has a red sceen.
May 25, 2008 | RCA F32444 32" TV
Rca tv model # 27v412t
What are your sympoms? keever
Mar 02, 2008 | RCA 27V520T 27" TV
RCA 27V412T
ok! change all tact switches! your tact switch has abnormal resistance! thats why your tv is changing system!
Oct 01, 2007 | RCA F27669 TV
Toshiba 36A50 36" TV Logo
113 people viewed this question
Top Toshiba Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
