Question about Hunter Fan Company 5/1/1 Programmable Thermostat
Thermastat wont shut off automatically - Hunter Fan Company 5/1/1 Programmable Thermostat
Have a braebum 3000 funice stays on for couple sec.then shuts off turned heat up to 78 but thermastat wont go past 68 it cold
I would check the flame sensor is clean also check air filter you could turn off the power to the unit and see if it resets it self .
Dec 08, 2016 | Heating & Cooling
My thermastat keeps shutting off and sometimes I have to hit it to come back on. How do I get another thermastat or how do I fix the problem?
If the settings are not holding true, then the controller is defective. Failure could go both ways, shut off prematurely or not shut down when necessary. Over heating could cause a fire, so replace the device ASAP.
May 10, 2014 | Masterbuilt BUTTERBALL Indoor Electric...
Set thermastat to 350 shuts off at 425
Get a gas fitter to do it mate safer bet
Aug 07, 2012 | Imperial IFS40 Deep Fryer
96 Buick Park Avenue, heater wont blow hot air. How can I tell if it might be the thermostat or the heater core?
Start the car and let it warm up. After it is warmed up open the hood. Look for your top radiator hose, and see if you can squeeze the hose, if the hose is hard to squeeze, the thermastat is stuck shut. If your heater core was out, it would be leaking badly.
Feb 26, 2011 | 1996 Buick Park Avenue
Furnace lights right up, but will not shut off with on-off switch or thermastat switch? checked out the thermastat switch and that works fine.
Disconnect the thermostat wires from the gas valve, if unit still runs; you have a short in the gas valve and it needs to be replaced.
Feb 22, 2011 | Empire DV-215 Direct Vent Natural Gas...
OVER EATS
Ehhh easy solution check you thermastat if that its sticking shut wont let coolient go thru causing it to over heat
Jul 11, 2010 | 2000 Chevrolet Venture
I do not know the model number of my honeywell thermastat. It is square with 4 arrows on the face. Please tell me how to set the thermastat. I press the buttons and see you set for differnt time of the...
press and hold the arrow key for about 3 seconds and release. this puts it into the set mode. then adjust the temp as desired. when you have it, leave it. it will automatically set to that temp in a few seconds
Dec 06, 2009 | Heating & Cooling
Runs, but not automatically.
replace the thermastat or also called the cold control
May 14, 2008 | Refrigerators
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
170 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
