When i print normal pages or pdf doc i get no issues or error codes , however as soon as i want to copy a document through the scanner i get error code 59.00.30 which relates to fuser motor , however i can print normally without the scanner with no error codes
SOURCE: Error Message "Page too Complex"
Hi Sccfire, This apparently is a fairly common problem with the 2800 series printer and associated with connection to a PC using USB. It can only be overcome by manually configuring the printer?s USB port to work in standard mode rather than at high-speed USB2.0 mode which probably won?t be to much of a problem. Here is a link from a support page on HP?s site that should walk you through the process: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00506095 Let us know how it goes and please don?t forget to rate the posting.
SOURCE: software issue - .pdf's not printing properly
We had the same problem. Ended up using the "print as image" option in Acrobat print dialog, then they came out OK.
SOURCE: C6180 printing slow
This could be from the image you are printing. If you are printing from a computer or memory card, the dpi (dots per inch) may be higher than some.Standard printing is typically 400dpi, and you can change the settings on your computer or the printer directly. Memory cards and some photos from your computer may be 600dpi and will likely take much longer to print since there is more "color information" that it is trying to fill.
Let me know if this helps.
SOURCE: ''Page too complex'' message on HP color laserjet 2840 Multifunct.
On the printer, hit the menu button
Then navigate using your left arrow button until you see Main Menu - Service, then hit enter
then use the right arrow to navigate to high speed usb and hit enter.
it should now show on, use the right arrow once to change it to off and hit enter 2 times
let the printer reboot and its should be fixed
SOURCE: can't print entire pdf documents only first page.
Try this
For Adobe Acrobat Professional 9:
