Question about DISH Network Home Security
How do i reset my dish reciever - DISH Network Home Security
Posted by m pouris on
  • DISH Network Master
  • 18,397 Answers
The most common way is unplug the power cable for 5 minutes.
Posted on Jul 07, 2014
How to Set Up the Kbox Pro Digy (FTA Receiver)?
-Extract files (factory bin & version bin)
http://www.abadss.com/forum/983-kbox...te-v2-0-a.html
-from remote, menu-config-system recovery & select delete all channels then factory reset
-insert USB into port in front of reciever, menu-utilities-data transfer-data download (from USB storage)-factory bin (version 1.81)
-menu-config,system recover y and select factory reset
-menu-utilities. data transfer, data download from usb storage-select latest bin (version 2.18)
-menu-config-system recovery-factory reset
-plug khub into reciever using black serial cable, also plug into network cable running to your router or switch
-from controller-menu-utilities-data transfer-data download from USB storage, then select khub activation
-menu-installation-options and make sure all AU options are set off and mode is set to network
-menu-installation-dish settings & config satellites you have setup dishes, then press red button on each satellite to scan in channels
-menu-config-network and change mode to DHCP press green button on remote and wait for it to be complete
-once previous step is complete, turn reciever off with remote, then from back. Wait 30 seconds, turn unit back on
Oct 20, 2016 | Video Game Consoles & Games
Screen freezes, reciever reboots
Hi there Richard! My name is Kimberly and I form part of the Social Media Department with DISH. It is my pleasure to help you with this matter. Please try resetting the receiver by unplugging it from the wall for 10 seconds. Plug it back in, allow it to power on by itself, acquire signal and download the guide. If issue persists please feel free to reach me at: [email protected] for further assistance.
Kimberly.Escobar
Social Media Representative
DISH L.L.C
Nov 17, 2013 | DISH Network Televison & Video
Remote doesn't work with reciever
1)Reset the code
2)tight the spring very well with pliers for better contacts
3) resolder the wires contacts batteries
4) Open the remote control for clean the keypads, from oxide, dust,with special spray contacts cleaner.
5) Proof.
God bless you
Jun 21, 2012 | DISH Network IR Remote Control
Satellite dishes wen down during storm. Attempting to find signal. SDHBH box is unresponsive. Is there a hard reset procedure?
Yes,unplug,replug the box back like about an hour later.The box,will reboot and updated it software.The incomming broadcasting signal should be back.If not storm,did more damages to the LB reciever connected on the dish itself.Must call Dish Network to check it out,might have to replace it.
Mar 21, 2011 | Hughes SDHBH DirecTV DTV Receiver
Receiver taking a long time to transmit reciever
I assume that the HDMI works fine if you go directly from the dish receiver to the TV with either HDMI cable. And try it with a different source (DVD or x-box) in the same input port.
Take it to a Radio Shack there service centers can repair Onkyo in warranty. Most Onkyo receivers carry a two year warranty.
Nov 18, 2009 | Audio Players & Recorders
When i watch dish network my theater system wont work ,only if i watch dvd it works
I run my s video from the dish reciever to the tv/satillite s video input and the digital audio to the digital audio input on my reciever. The reciever is a sony V333ES and have no problems at all.
May 30, 2009 | Coby DVD-958 Theater System
Sharp tv dish network
that maybe the case..you could put a shielded barrier(copper coated poly) between them.sounds like it's a little too sensitive
Jun 20, 2008 | Televison & Video
Home Security Logo
47 people viewed this question
Top DISH Network Home Security Experts
Marvin
Marvin
Tom Chichester
Are you a DISH Network Home Security Expert? Answer questions, earn points and help others
