You must install MS Visual C++ runtime libraries because it is needed by some applications to run. Download this runtime libraries at microsoft:
for 64 bit computer:
http://www.microsoft.com/en-us/download/details.aspx?id=14632
http://www.microsoft.com/en-us/download/details.aspx?id=15336
http://www.microsoft.com/en-us/download/details.aspx?id=21254
http://www.microsoft.com/en-us/download/details.aspx?id=30679
SOURCE: Internet explorer not opening (memory problem?)
if your system is running low on memory, the pc will not be able to run the programmes as normal as it will use virtual memory which enables the system to open up programmes that you use regularly without searching for the start up files reciding on the hard drive, but if your system is low you will get these screen messages. Either upgrade the system with more memory or check what programmes you have running on start up using your memory, press start>run, then type msconfig and look at the start up tab and untick any unnecassary programmes that start up,then click apply for a restart, as this will release some of your memory. On the other hand there may well be a problem with internet explorer itself also, so you can download the latest IE7 from microsoft if you wish and see if this solves the runtime issue
