Question about Palm Zire Mono M150 Handheld
I have a palm zire m150 but can not sync with windows 8.1 please help
2 Related Answers
Anonymous
  • 32 Answers
SOURCE: INSTRUCTION BOOK
You can get all the help information you want from the Palm Zire website.
Posted on Dec 02, 2007
Anonymous
SOURCE: hot sync function does not work with windows 7
http://kb.palm.com/wps/portal/kb/common/article/47831_en.html#zire
Posted on May 23, 2010
I cant sync m150 with W 7
HP, Palm's new owner, has offered
Palm Support Palm Tungsten E2 Palm Desktop 6 2 and HotSync Manager... to help sync PDAs to Win 7. However it lists the z22, which used Palm OS 5.4, rather than the m150, which used Palm OS 4.1. I don't know if that will provide a barrier, but good luck in your attempt.
My Palm Zire M150 touch screen is badly misaligned. How do I reset the alignment?
the screen says use stylus to tap center of target ...i do that and it goes to upper left corner i tap and it goes lower right corner and back and forth between the to corners?
1helpful
I NEED a copy of the owners manual for the Palm Pilot / Zire m 150 If it is possible to have that E-Mailed I would sure appreciate it. Then my wife will stop bugging me about it also.
Found a Zire PDF manual "Handbook for Palm (tm) Zire (tm) Handheld" at the following URL "http://nettopdf.info". You can also do an Internet search for PDF "zire_ug.pfd". The graphics are for a Zire Mono M150 but I believe this is a general manual for most early Zire models. Found on 2/6/2011.
Hot sync function does not work with windows 7
Need software for Zire M150 that runs on Windows Vista?
Older palm products and vista aren't compatible. You either needs to transfer info via bluetooth or upgrade your palm if you wish to continue using vista. As far as transferring, possibly a memory card.
INSTRUCTION BOOK
Palm Zire Mono M150 Handheld Logo
Top Palm Computers & Internet Experts
Ekse
Muzahura Frank
Mandeep  Singh
Mandeep Singh
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
