Speed Dial Keys
The fax number and other data for a particular destination can be programmed using a 3-
digit Speed Dial Number. This feature allows you to transmit a document to the
particular destination by pressing the Speed Dial Key, entering the 3-digit number and
pressing the START Key. You can program a fax number in any of the 100 Speed Dial
locations, number 001 to 100.
Entering
1 Press the PROGRAM Key and scroll through the
menus until you reach the DIAL REGISTRATION
Menu. Press YES to begin programming.
2 Press 2 or scroll down to the Speed Dial menu and
press YES.
3 Enter the number of the location you want to
program and press YES.
4 Enter the Telephone number you wish to transmit
to and press YES after checking to see its OK. If
you want to enter the sub-address, press the Down
Arrow Key.
5 You can press sub-address up to 10-digit.
REGISTERED! KEEP?
OK=YES (EDIT/DEL=NO)
EDIT *DELETE
-SELECT&PUSH”YES”-
DIAL REGISTRATION?
YES / or 1-6
2 SPEED DIAL?
OK=YES
SPEED DIAL =_
OK=YES
OK=YES (SUB= )
SUB=_
OK=YES
Edit/Deleting
1 If you wish to change any entry, a screen allows you to accept or change.
2 If you wish to change a Key that was previously
programmed, this message appears. Press YES to
keep this location as is, or NO if you wish to edit it.
3 If you choose NO, use the arrow keys to select
either EDIT or DELETE and then proceed with the
needed changes.
Group Dial Keys
Instead of their regular functions, any of the One-Touch Keys can be used as Group Dial
Keys. Destinations already stored for One-Touch, Speed Dial can be entered in a Group
Dial Key. Each Group can contain up to 50 locations.
Entering
2 Press 3 or scroll down to the Group Dial menu and
press YES.
3 Press the One-Touch Key you wish to use.
4 Press YES to accept your selection.
NAME=_
OK=YES
REGISTERED! KEEP?
EDIT *DELETE
-SELECT&PUSH”YES”-
Btw, Iām available to help over the phone in case u need at
https://www.6ya.com/expert/normanj_7893313f0751935f
