It your Clutch Needs to be changed here is the part
Dyson clutch belt assembly for DC07 amp DC14 900252 04 473
SOURCE: brush bar does not turn & makes a loud noise
You need to clean your roller and replace the clutch assembly that drives the belts. poorly designed vacuum with many flaws.
SOURCE: My dyson D17 is making an incredibly loud noise,
Remove the bottom cover plate and rotate the brush by hand. Look for things that make noise like stones caught in the brush path, bad brush bearings, bad drive belt.
SOURCE: Hello. My dyson dc04 keeps making a loud screeching noise.
remove base cover by 3 'screws' 1/2 turn anti clockwise and clean well remove fibres replace cover and re try.
SOURCE: My dyson DC17 makes a loud noise when i tip the
Loud noises are usually caused by worn belts, unbalanced roller brush or debris in the roller brush. Check these things. Here is a link to the belt you need:
Dyson DC17 Replacement Belt
SOURCE: dyson vac has started to
Does the whining noise come from the motor or the brush area?
If it's from the brush area, it's probably the belt. Check to be sure the belt is not worn. Sometimes belts will glass up and slip. Also, check to see if it is still completely on as it should be. You may need to replace the belt.
I woHope this helps, if it does, please place a vote for me. Thanks,
Handie Andie
Testimonial: "good answer"
Hi.
You either need A new clutch or clutch belts need replacing.
Its a lot to describe so try this it has manuals on how to do the job.
