Question about Sharp MX-2700N Color Copier
We have a code h4-30 on a sharp mx-2700n how do I reset?
We have a code h4-30 on a sharp mx-2700n there was paper in the fuser unit which has been removed, how do I reset the machine? I have tried "#*C*" however this doesn't seem to enter the service mode, any ideas? Thanks J
Posted by MONDITAL LTD on
Skelton Business Equipment
    Guru:
  • Sharp Expert
  • 106 Answers
You need to make sure the machine is in Copy Mode when you hit
# * C *
enter 14, then touch start
execute on the screen
the machine will reboot and the code should go away.
If it persists you may need some maintenance. If you're in Houston give us a shout. Our labor rates are low compared to the other Sharp dealers in Houston.
Skelton Business Equipment Houston Copiers
http://www.youtube.com/equipmybiz
Posted on Aug 06, 2014
5 Related Answers
Anonymous
  • 148 Answers
SOURCE: Service Mode On Sharp SF2530
A little rusty on this machine, but try this.
This code means you have had to many paper jams in the fuser without removal. Make sure all is clear in the fuser and exit sections.
Then on the control panel you will press a series of buttons as follows.
Press the Clear, Press interrupt, Press Zero, Press interrupt, Enter # 14, Press start, That should reset the machine...
Hope that helps...
Lbcoaster
Posted on Jul 02, 2008
Bubbabear64
Tim Babcock
  • 2794 Answers
SOURCE: "machine gun clicking" sound - fuser drive/motor gear area
Sometimes the clicking noise can come for the developer cartridge or the drum. you can carefully take them out and see if they turn freely.
Posted on Aug 12, 2008
Anonymous
  • 24 Answers
SOURCE: error code h4-01
P * C * enter sim 14 press copy key then CA. Machine should reboot. if problem re-occurs your thermostat in the fuser has tripped
Posted on Dec 01, 2008
Anonymous
  • 143 Answers
SOURCE: Sharp MX-2700N - Error Code - 'Call for Service E7 - 05'
E7 is only part of the code. It could be a hard drive problem, memory problem, laser problem, or a loose connection on one of the boards.
Posted on Aug 01, 2009
Adorjani Laszlo
  • 1316 Answers
SOURCE: What do it do to fix ''maintenance required Code: CA''
The service acces code C-0-0-C,or C - interupt key -0-interupt key.Acces the list of commands maintenance preset counter setting and set to a new value,or maintenance counter clear.
Posted on Aug 02, 2009
How do I remove Error code L4-02
L4 errors relate to motors. L4-02 specifically means Paper feed motor locking trouble.
You will need to take it in for repairs.
Nov 05, 2015 | Sharp MX-2700N Color Copier
What shall i do to return my sharp mx-2700n copier to operation?
have you check the sensor actuates on the registration section
Oct 19, 2015 | Sharp MX-2700N Color Copier
I have a sharp 2700 copier with code H5-01
HI
H5-01 means you have had five consecutive jams, it would suggest there is either something blocking the paper path, or the paper is not being picked up at all.
Try resetting the machine by the following:
Program, *, clear, *
It will then ask for a simulation code, enter 14 and press print, are you sure?, press yes. Clear all, clear all, should reboot the machine and try again.
If it continues to jam, try a different cassette.
Cheers
Andy
Apr 23, 2015 | Sharp MX-2700N Color Copier
Maintenance require code vc
The VC code on a sharp mx-2700 is the cyan developer has reached its maintenance cycle of 60,000 copies. to clear this code enter sim mode #, *, C, * then 24-5 to clear dv count.
Jan 28, 2014 | Sharp MX-2700N Color Copier
When i start sharp- mx27004 printer then show problem is ''call for service code f2-40''
Hello.
Sounds like you need a service call. But, the tech should first check/inspect the Drum, Transfer Unit, and Fuser Unit and then reset your counter.
Hope this helps.
Apr 10, 2010 | Sharp MX-2700N Color Copier
I have a sharp copier MX2700N with an error code of FK1. What do I need to do to fix it?
fuser count has reached 200,000 copies. hit P*C* then 24, start, then 4 start. select Fuser Unit and Fuser Acum Day then execute at bottom then yes. Hit CA button. copier should reboot and clear code.
Apr 17, 2009 | Sharp MX-2700N Color Copier
Error code h4-01
Dec 01, 2008 | Sharp MX-2700N Color Copier
Error Message H5-01
H5-01 = detecting 5 consecutive POD_1N jams
Check the fusing section for jam paper. (winding, etc.)
Use SIM14 to
cancel the trouble.
Entering the simulation mode
1) Copy mode key ON → Program key ON → Asterisk (*) key
ON → CLEAR key ON → Asterisk (*) key ON → Ready for
input of a main code of simulation
enter 14
accpet yes clear..
machine should restart.
To fix this you need to have the fusing unit looked at... could be various problems causing this , from bad paper to bad rollers?
Nov 24, 2008 | Office Equipment & Supplies
Sharp MX-2700N Color Copier Logo
1,794 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
