Question about Tag Heuer Link Watches
Where can i get a manual for Tag Heuer Link CJ1110
Want to know what functions there are and how to operate them
5 Related Answers
Anonymous
  • 65 Answers
SOURCE: How to remove links on a tag heuer cj1110.ba0576 watch
tag needs a special tool, try a jeweler should only cost 10-15 bucks!
Posted on May 11, 2008
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: looking for the user manual for Tag Heuer Aquaracer watch
They were just hiding it:
http://ww2.tagheuer.com/_documents/manuals/EI2252_en.pdf
-Tha Mp3 Doctor
Posted on Dec 31, 2008
Anonymous
  • 3 Answers
SOURCE: Tag Heuer Formula 1 Mens watch
battery number 395!
Posted on Jan 02, 2009
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: I can't seem to set the time on my used tag heuer watch
Probably your watch has a screwdown crown and prior to attempt any settings you have to unscrew it. Some peoples fingers are stronger then others, so, try that with a pair of plyers. Cover your crown with a soft cloth and then grip with plyers(this will avoid any damage). Thread is right handed and unscrewing is done by turning the crown anticlockwise.
After setting the time don't forget to screw the crown back- it is for water resistance.
If you are unable to unscrew the crown, that means your watch is rusty and you will need watchmakers help.
PS If the watch is rusty, you can brake the crown off while trying to unscrew it. Don't panic yet, as in this case you will need a watchmaker anyway.
Don't forget to rate, please.
Posted on Jan 10, 2009
Anonymous
SOURCE: How to set up time on TAG HEUER SLR CHRONOGRAPH ?
The crown at 3 o'clock is used to set the time and change modes. The crown at 9 o'clock is used to rotate the flange at the edge of the dial.
The A button at approximately 2 o'clock starts and stops the chronograph function. The B button at approximately 4 o'clock resets the chronograph.
Lap Timer: When the watch is displaying normal time, press the right side crown to switch to chrono mode (the hour hand will indicate CHRONO). This watch measures lap times, press A to start timing the first lap. Press A again to stop the first lap and automatically start timing the second lap (the hour hand will move to indicate you're on the second lap), and so on. You can measure up to 20 laps this way. When you're fininshed timing laps, press the right side crown to see the best lap time. To reset the lap timer, hold down B for 2 seconds. To switch out of chrono and see the normal time, just press the right side crown in.
Chronongraph: To time an interval that is not a lap, just follow the above instructions, but instead of pressing A to stop the first lap, press B and the watch will show the elapsed time to the nearest 1/100th of a second. Hold B to reset.
Crown at 9 o'clock: This crown rotates the inner flange at the edge of the dial and is used to measure total race time (i.e. the total of all the laps). Simply rotate the crown until the the little start trinagle on the flange is aligned with the minute hand. This way, the total elapsed time can be read at any time, similarly to how a rotating bezel works.
To set the time: Ensure the watch is not in CHRONO mode, if so, press the right side crown in. At this time pull the right side crown out until you feel a click.The position the second hand moves to indicates what is currently being set. If the second hand is at 9 o'clock, you are setting am hours, press A repeatedly to set am hours. Then press B and the second hand will move to 6 o'clock, pressing A repeatedly will set the minutes. So on for year (11 o'clock), month (12 o'clock), and day (1 o'clock).
Posted on Apr 03, 2009
Clasp for Tag Heuer aquamarine watch BA0751
Once you have the part number you can search ebay and if lucky you will find the clasp there.
Jan 22, 2013 | Tag Heuer cj1110.ba0576 Wristwatch
Tip
TAG HEUER quartz chronograph manual.
Follow this link and download original manual for TAG HEUER quartz chronograph: http://www.tagheuer.com/the-collection/link/men/quartz-chronograph/index.lbl?w=CJ1110.BA0576
on Feb 09, 2010 | Watches
I cant get my minute and hour hands to zero out on my Tag chrono
If you haven't got the user manual, you can go to http://www.tagheuer.com/the-collection/link/men/quartz-chronograph/index.lbl?w=CJ1110.BA0576, where you will see a small menu on the right.
Click on "user manual" to download the instructions, which include the hand re-setting procedure.
Mar 20, 2011 | Tag Heuer cj1110.ba0576 Wristwatch
My tag heuer wk 1111-0 has a serial # mb 9169 ; how old is this watch?
mcdevito75 here, The number on the movement itself is the number you need, Look for any small watch repair shop in your area for an estimated age, or you can contact Tag Heur online, try tag Huer watch.com
Jul 07, 2010 | Tag Heuer cj1110.ba0576 Wristwatch
How to setup the alarm to my tag formula1
I couldn't locate your model but if you go to http://www.tagheuer.com/the-collection/tag-heuer-formula-1/men/quartz-chronograph/index.lbl?w=CAH1113.BA0850 , you will find the details of a similar watche. In the menu at the side you will see "instruction manual".
Jun 03, 2010 | Tag Heuer cj1110.ba0576 Wristwatch
My tag watch date function is jumping several days at a time. what is the problem?
must likely the date jumper is either too weak or broken.
You will probably have to take that watch to a watch repair person since the dial and hands have to be removed to see what the problem is
Oct 21, 2009 | Tag Heuer cj1110.ba0576 Wristwatch
Tag link - second hand issue
http://ww2.tagheuer.com/_documents/manuals/EI2241_en.pdf
The battery is running down - this is the Tag Heuer early warning system for low battery.
See web page above which is from the Tag Heuer site.
Oct 16, 2008 | Tag Heuer cj1110.ba0576 Wristwatch
Tag link chronograph
It sounds like the button is not making contact with the movement curcit board. Take it to a watchmaker who has a pressure tester so he can look and see if in fact this is the problem, and then can re-seal your watch to the exact number of meters your watch can go diving to.
Jun 10, 2008 | Tag Heuer cj1110.ba0576 Wristwatch
May 10, 2008 | Tag Heuer cj1110.ba0576 Wristwatch
Tag Heuer Ladies Professoinal 2000
Hi Dude, it's one of those things your going to cuss once you know. Just unscrew the Bezel.Thats it. Steve
Mar 15, 2008 | Tag Heuer cj1110.ba0576 Wristwatch
Watches Logo
148 people viewed this question
Top Tag Heuer Watches Experts
Janelle Schoonover
Janelle Schoonover
Ekse
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
