Location of fuses on LT 1000
SOURCE: craftsman LT 1000 deck belt diagram
my clutch belt will not stay on the pulleys Craftsman 42 in. LT 1000
SOURCE: need a blade engagement cable diagram for a 2002 craftsman lt1000
as far as i know, there is no diagram available for the cable replacement. it is covered briefly in the owner's manual, but the best way to do it is to study carefully how the old one is routed, and replace a step at a time
SOURCE: how to install clutch in craftsman lt 1000
there is no clutch,, you have an arm with a pulley that is spring loaded .. when u release the " clutch" this arm pulls a pulley against the belt taking up the slack ,, make sure the belt is not worn ,, or the spring is broken or loose
Testimonial: "this was a great help thanks a million"
SOURCE: Craftsman LT 1000 I replaced the battery,
be sure you are sitting on the mower with the clutch pedal pushed down,blade engagement in off position,
there may be a safety switch bad or a wire pulled off of one or more of them or a bad starter solenoid which is a high failure item.
Check safety seat switch wires under seat,look under mower for clutch pedal switch wires located under mower near clutch pedal, check the blade safety switch if its a manual blade engagement? The (starter solenoid) you will need to find the red wire on your battery and follow it until you find it or from the starters red wire back towards battery.
Once you find it inspect the solenoid to be sure wires are in tact,then find a dc volt meter and check to see if you have voltage(12volts dc min.) to the small red wire hooked to the solenoids coil (near the bottom) when the the ignition key is turned to start position(one of your meters wire to the coil wire and one to a good ground,,if your meter goes backwards reverse the meter leads)Note:lock the clutch pedal down before you do this) If you have voltage to this wire when key is turned to start position? solenoid is most likely bad or if you dont have voltage trace that wire backwards until you find voltage then you may have found your culprit.
SOURCE: lost key to craftsman lt 1000, where can I get raplacement
sears has them on a hook where the filters are located.
