Machine was stored. put it back in use, won't work, just says ventilate. pushing hot water button gets no response
SOURCE: I have a Saeco Royal
Hi
You only push the water button. Don't turn the knob, that is just for steam. There is a button for the cappuccinotori though, that you push.
SOURCE: my saeco is displaying ventilate.
You might have a restriction or blockage in the brew head. This is from fine coffee residue and oils that will build up in the passages of the brew unit. To fix.
Remove the brew unit. Holding the handle, on the top left side is the brew head, there is an outlet pipe that exits the front side towards the machine. 2 screws hold it to the top. Remove the 2 screws while holding the manifold ("L" pipe assembly). Once they are removed, lift the l assembly off (be careful, there is an O-ring, spring and at the end a black rubber disk or crystal ball). Do this over a towel to prevent loosing small pieces, mainly the crystal ball.
Now remove the brew screen, by holding the screen with your finger and twisting the thumbscrew (remember, thumbscrew), DON'T use the key to install the screen, use your fingers.
Once the screen is out, look at where the screen was. There are 2 holes. A big one in the center and a small one to the side.
With the brew unit upside down over the towel, insert a paperclip into the small hole and force anything out the other side. I have gotten worms almost a 1" long from this passage. The paper clip has to go from this side to prevent damage to the seat on the other side.
Clean then reassemble. Brew unit on towel right side up. Drop the crystal ball in first. Then the spring small end first on the crystal ball.
Now the O-ring over the spring, then place the manifold on top of that with the pipe towards the machine. Insert your screws (I turn them backwards a little with a little downward pressure until they feel like they drop into the threads. They should turn down easily, if not back them up a little more ( we are trying to find the old threads) and tighten. Install screen, and tighten with your fingers. The screen just needs to be flush with the bottom of the brew head. That should do it.
Asker's Testimonial
Testimonial: "thanks will try it out"
SOURCE: saeco royal profesional machine says
Hi.
The machine will stay locked until Ventilate is on.
Try following the indications here: The following procedure works when you get the ventilate error: The Ventilate sign can....
Regards.
Ginko
SOURCE: Saeco Royal Machine says "ventilate", but when we
Hi
For the Royal Pro there is a button that has a drop sign(water drop) on it. You have to push the drop button to flow water from the steam wand. This should clear the ventilate but if it doesn't check my other tips for "Ventilate"
