Samsung RS2534 Side by Side Refrigerator Logo
A
Anonymous Posted on Jul 07, 2014
Freezer freezes refrigerator worm - Samsung RS2534 Side by Side Refrigerator
Jorgie the appliance guy
Level 3:
Top Expert:
  • Samsung Master 5,639 Answers
  • Posted on Apr 10, 2015
Samsung Master
Level 3:
Top Expert:
Answers
5639
Questions
Helped
1523782
Points
32630
Check the cold control thermostat with a meter for both OHMS and volts ( VOLTS is a live test with fridge plugged in so be careful) It must show 110 volts. An open or thermostat that reads infinity will not allow the proper cooling and defrosting cycles to operate and may in fact stop anything from happening as if there is no power to the unit?
ALSO CHECK THE AIR FLOW VENT SYSTEM and THERMISTORS At times it can get stuck to far closed or open. Some units feature a digital electric adjusting vent system while others are manually set. Check for any ice build up or other obstruction in the vent damper, see if u can manually open or close it. Some times when u have the settings set to the highest it closes off one area while allowing to much cold air flow to the other area!
Freezer freezing and refrigerator freezing
Search round the top/bottom/sides of fridge and freezer for a regulator switch. Usually a small serrated wheel numbered 1-5. It should be set at 2 or 3. Any more and you will freeze up.
My two year old hotpoint FFA52 fridge freezer is not freezing the foods in the freezer and the fridge's body is worm, it sounds like it is working it just this two problem.help
since its been 2 yrs , there might be a problem with the condenser , the gas would have been empty, so its better if you get it checked by a technician, and refill the condenser.
thanks for rating Good luck
1helpful
Ice jams up the worm at the bottom of the icecube dispenser and the worm does not move the ice and ice jams in the crusher part.
Try turning the temperature down on your freezer one number. Sometimes if it is not cold enough, the cubes can stick together and cause a clog.
1helpful
Whirlpool runs, but freezer not freezing and frig not freezing
If the compressor is running but the unit is not cooling you may have lost the refrigerant.  See if the condenser coils at the back or bottom are hot.  If they are only warm then the refrigerant is low and can be recharged.  Service tech should check for leak in coolant system.
Bottom freezer "on" but not freezing and not making ice
Refrigerator running but not that cold, freezer running also but not freezing at all. Also not making Ice
Hotpoint rfa18 Fridge Freezer
Is the back wall full of frost? If so you have a defrost problem, most likely the defrost is stuck in the run mode. this is located above the controls area in the fridge.
6helpful
3answers
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
2answers
Crystals forming all over freezer
Sure sounds like the defrost cycle is not working. Could be a bad defrost heater, t-stat or timer.
Top Samsung Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
