Sony Playstation 3 (PS3) Console Logo
Question about Sony Playstation 3 (PS3) Console
What is my playstations wifi password?
I use my ipod for kik and ect . the wifi that's closest to me is coming from my playstation
Todd Yates
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 38 Answers
Your PlayStation does not control your Wi-Fi. The Wi-Fi will most likely be emitted from a wireless router. The router determines the Wi-Fi password. You can reset the password, but you will need to know the IP address of the router and the logon username and password to access it. If you have that information, type the IP address of the router into a web browser's address bar. This will take you to the router's home page on the network where you can reset the password.
Posted on Jul 17, 2014
5 Related Answers
Anonymous
SOURCE: playstation 3
you just go to your e-mail it should send that information to you
Posted on Feb 20, 2008
Anonymous
SOURCE: parental control password
  1. say yes to level 8
  2. when asking for the 4 digit code hit select
  3. enter7444
Posted on Aug 19, 2008
Anonymous
  • 31 Answers
SOURCE: playstation 3 freezing
PS3 is one of the most amazing gaming device but like other competitor gaming devices (Xbox and Wii) It also has some problems like Freezing up. You may check out the informative Article at ezinearticles Remedy for PS3 Freezing up
Posted on Mar 03, 2009
Anonymous
  • 16 Answers
SOURCE: problem with playstation 3 games and blue-ray
I had a similar problem. My PS3 was not starting the game discs when I inserted those to the PS3. Also those game discs were not visible in the game menu.
I did not have problems with the normal movie DVDs or Movie Blu Rays. Those were working fine.
Actually I was able to start the game disc with a special trick, which required start some application, such as a downloaded game, let it start, and then hit the PS home button. The game disc title then shows up under the game menu and from that point remains viewable until the disc is ejected or the console is turned off.
In case you have the similar problem, I was able to fix this problem by executing the following steps;
The PS3 has a special Recovery Menu, which you can access in the following way;:
1. Turn off Playstation 3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION 3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION 3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION 3 System
Select option "Rebuild Database".
After the PS3 has executed this DB rebuilding operation, the disc games will be visible again under the game menu and are also starting automatically when inserted to the PS3.
Posted on Jun 17, 2009
Anonymous
  • 149 Answers
SOURCE: my playstation 3's first screen has no icons to
try rebuilding the database and the file system in recovery consol
to get to the recovery consol press and hold the power button when ps3 is in standby mode(red light) till you hear a double beep. sometimes the ps3 does a beep then another beep and goes back into standby thsi is fine just release the power and quikly press and hold it again till you get double beep.
like on my 80g system it goes like this
ps3 standby...press hold power.......beep .........beep........stanby again....release and hold power again.......beep .........double beep...release power now you should be in recovery menu.
Posted on Oct 28, 2009
2answers
I forgot my email and password. How do I get into my kik account?
Hello, First click on forgot my password and reset it or call kik cust support:
1-800-479-6603 KIK Customer Service Phone Number
How do i get my Ps3 to obtain the IP address?
Wireless or Wired - if wireless you have to match the wireless settings of the PS3 with your home's internet router WiFi settings (same protocol and valid password).
If wired, you just plug it in and, assuming the route is working with other wired devices, that router should issue an IP to the PlayStation - but again you need to go into Settings of the PlayStation and make sure you know which setting it is currently using - wired or wireless, not both at the same time - and then make sure the WiFi settings, in particular, match that of the Internet Service Provider's Router wifi settings you have, which work with other wireless devices in your house (hint: The playstation will accept the same settings as all the other devices in your house which are wireless, so once you match them, it should work - unless the PlayStation itself has a hardware problem - that issue is beyond the scope of this forum to help you resolve).
Why wont my Ps3 obtain the IP address?
Duplicate post to another just answered. Here is the same answer:
I have tried to set my playstation 3 online keeps asking for wep key what is this and were do i find it
Your PS3 is most likely trying to join a WiFi (Wireless) network. Sometimes WiFi networks have passwords to keep people out. The PS3 is asking for a WEP key because it is asking for the password so it can join that WiFi network and get online. Try to find your WEP key for your router. If it is not your router then you will be unable to join that network since it is secured.
I can't access the playstation network, Netflix, or PS store but I can access the Internet. I have wifi and my iPhone works fine. When I try to log in it says "connection with PS network timed out
Turn the playstation off and then back on. You have to be connected to PSN to play Netflix and connect to the PS Store--is something maybe wrong with your username/password?
I had a problem with my router and it had to be reconfigured. When I try to connect to the internet with my playstation it asks for a username (email address) and a password. What password is it referring...
this is your plastation network online information you signed up for when you first went online to play video games, shop at there store ect.
If you forgot this information go to this link, and you can get password reset being you forgot it if you know what email you used.
https://store.playstation.com/login.gvm
Wifi works well on laptop but not on ipod
I know that ipod has a weaker wifi detector than laptop
1helpful
I would like to play my ipod through my playstation, is it possible. I have a USb connection but the playstation does not pick it up. Carien SA
i have an 80gb ps3 this is what i done
  1. step 1 Sony PS3
    Turn on your Sony Playstation 3 console and wait for the main menu to come up.
  2. Step 2 Ipod USB connector. Connect your Ipod to your PS3 with the USB cord.
  3. Step 3 Go to the MUSIC icon.
  4. Step 4 Scroll Down to USB Device (Ipod).
  5. Step 5 Press the Triangle button. (If you press X you will not be able to play the songs.)
  6. Step 6 Press the X-button on the "Display All" icon.
  7. Step 7 Scroll down to "Music"
  8. Step 8 Now you can view all of your music and songs and play your Ipod on your PS3! You can create playlists and listen to all of your favorite music from your ipod through your Playstation 3.
1helpful
I dont know my password to my wifi
If you havent set a password for your wifi, then typically the password is a set of numbers located on the router usually on the bottom sticker
Top Sony Video Game Consoles & Games Experts
Marvin
Marvin
ELECTRICKSUSA
ELECTRICKSUSA
Steven Wander
Steven Wander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
