Question about Neff U1421 Double circotherm Electric Oven
What are the dimensions of Neff u1410 - Neff U1421 Double circotherm Electric Oven
1 Related Answer
Anonymous
SOURCE: Neff U1410 main oven trips the main RCD. Occurs
I have a u1421 with the same problem! I notice the fan doesnt run too well, sometimes it doesnt run at all, needs a prod to get it running. I suspect with no fan, that the element gets far too hot, and then starts to leak to earth, tripping the RCD. I'm gonna try buying a new fan motor - you should ckeck if your fan is running full speed OK.
Posted on Nov 02, 2009
I have a new neff built in oven. I turned it off over an hour ago and the fan is still running. Surely this is not right. Any suggestions.
Hello, Sylvia -
Since your Neff oven is new, I hope I am correct in thinking you have the owner's instruction manual for the oven and you already checked there to see if there were any troubleshooting tips regarding the fan still running after turning the over off over an hour prior.
If you do not have the instructions for the new oven, check here:
http://www.neff-home.com/uk/service/manual
Note: You will need to supply the E-Nr number for the oven. If you do not know where to find the E-Nr number, on the web page cited above, click or tap on the link for the rating plate finder.
After checking the owner's instructions for the oven, the next thing I would suggest is contacting Neff Specialist. See the information here:
http://www.neff-home.com/uk/service/support
Talk to a Neff Specialist.
You new Neff oven is most likely still under warranty.
Best wishes.
May 01, 2018 | Neff Ovens
Where can I get installation and operating instructions for a NEFF 29c warming drawer?
Hi Pat,
I suggest contacting Neff directly. You can email them or telehone them from choices on the page linked below:
http://www.neff.co.uk/customer-service.html
Apr 14, 2015 | Neff Ovens
Need a manual for a neff fan assisted oven
Hi, Same can be found on neff website, Please find the same.
http://www.neff.co.uk/getting-started-with-your-neff-oven.html
Aug 25, 2014 | Neff Ovens
Front cool touch facia model Neff | B1262W0GB/01 | Built-in Oven | white needs to be replaced please help source and how to fit
Part number is 289510, I have checked with Neff and unfortunately is is no longer available. The part was 230 quid!!! and that was just for the front portion as the fascia comes in three parts. I have added the link so you can check yourself, just enter B1262W0GB/01 in the search box and click on Page 2
http://www.neff-eshop.com/eshop/neff/gb/sparepartsearch1.htm
Feb 19, 2013 | Neff Ovens
How do I set auto timer on my neff oven to come on In a couple of hours ?
Here is the link to a short PDF file that explains a couple of setting on the Neff oven, including the automatic timer:
http://www.neff.co.uk/files/Getting_Started_Leaflet.pdf
Hope this helps. :)
May 20, 2012 | Neff Ovens
Oct 25, 2009 | Neff U1421 Double circotherm Electric Oven
I am looking to download a manual for a neff oven,
U HAVE TO TYPE IN GOOGLE DOWNLOAD AN INSTRUCTION MANUAL FOR A NEFF OVEN
Sep 29, 2009 | Neff U1721 Double circotherm Electric Oven
Neff U1421 Double circotherm Electric Oven Logo
109 people viewed this question
Top Neff Ovens Experts
Paul Carew
xxxxxx xxx
john h
Are you a Neff Oven Expert? Answer questions, earn points and help others
