Question about Kenmore 53092 / 53094 Side by Side Refrigerator
Brown stuff in water kenmore - Kenmore 53092 / 53094 Side by Side Refrigerator
I have a kenmore dishwasher with blue and green power wiring,and unknown how to connect it to the black and white wiring plug
You are missing a wire. On the Euro influenced stuff there should be a BROWN, BLUE and GREEN STRIPE.
BROWN goes to BLACK (hot)
BLUE goes to WHITE (neutral)
GREEN STRIPE goes to bare ground.
Here's a website for clarity -
Wiring Color Codes Infographic
Sep 26, 2017 | Cars & Trucks
My coolant is brown in the radiator and coolant tank
time to change the radiator fluid also flush out the system good the brown stuff is surface rust no big deal just have it flushed or do it yourself. make sure you have the proper coolent these days there are 2 main typs of coolent, to put it simply the green stuff and the orange stuff. my chevy truck takes the orange stuff. now you could be seeing old orange stuff and it may look brown to you so make sure you replace it with the correct fluid because they dont mix and you will do damage to your car. also if you find out you have orange coolent in your car you CANNOT MIX THIS WITH WATER.. it will also damage your car..if you have orange and decide to flush out the radiator it might be a good idea to have it done at a shop.. they will know how to do it correctly. if it takes green fluid its simple to flush and repalce it yourself because you CAN MIX WITH WATER. i hope this helps...
Jul 24, 2011 | 2001 Chevrolet Monte Carlo
Hi. I have a Kenmore Elite top-loading washer and in every wash load there are flakes of brown stuff, not rust but more like leaves. There does not seem to be anything wrong with the outflow. Thanks!
Run a few washes of rags or towels with plenty of BLEACH & VINEGAR (two quarts of white) a couple of times to remove most bacterial debris from your machine. There is no part of the machine that "creates" brown flakes, so it is either in the water inflow (check the water) and the way to see what is coming into the machine is to do a "load" without any clothes! Just have the tub fill and look at what fills.....Sounds like something under the tubs upper lip that's coming-off and into your tub during the wash and agitation cycles.
Oct 08, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
I noticed that when i put anti freeze and water in their is this brown milky stuff
the brown milky stuff is rust and you have mixed two different types of antifreeze together it formed a reaction,you will need to do a complete flush and top up with the correct antifreeze for your engine asap.DO NOT MIX ETHYLENE GLYCOL WITH ANY OTHER TYPE OF ANTIFREEZE..........
Jun 25, 2010 | 1999 Ford Taurus
Kenmore washer. leaking brown oil like substance
Oil leak can be bad, can be gearbox on top loaders / or bearing fault..
Oct 01, 2009 | Washing Machines
Digital revolution iron squirts brown water onto my clothes
Try an iron cleaning fluid or crystals. you can get the stuff at wallmart or similar stores. It usually works. Try using distilled water in the iron.
Jul 27, 2009 | Irons
Brown dirt-like looking "gunk" coming out of the washer
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Have you cleaned out your pump lately. Put the pellet inside the machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
Jan 10, 2009 | Kenmore 44832 Front Load Washer
Kenmore dryer
ck rear (or front if it has one)drum seals they tend to develop rust stains over time the rust comes off on clothes leaving brown streaks ..seals will need to be replaced although you may try a bleach and water solution first drum will need to be removed to replace seals
Nov 03, 2008 | Kenmore Dryers
Water line to Kenmore refigerator is brown
Some tubes turn brown gradually with age. This is normal. But if yours is not made of that material (not sure what its called), then it could be that the pipe is dirty. If this be the case, it is definitely better to get the line replaced, as it is definitely a health concern. I would recommend getting a filter fitted to the line as well, just as a precaution..
Sep 29, 2008 | Kenmore 53603 / 53606 Stainless Steel Side...
Cleaning
deacaled it use a special descaler produit not vinegar 1 part descaler 1 part water fill up water tank start let it drip for few second turn off leave it for 15 minute repeat untill empty after rinse very good very corosif stuff that descaler the machine is gonna work fine the brown stuff should come of but coffe is like dye calcium in machine is a killer brown stuff is not nice but the coffee is great cheers
Feb 03, 2008 | Coffee Makers & Espresso Machines
Kenmore 53092 / 53094 Side by Side Refrigerator Logo
24 people viewed this question
Top Kenmore Refrigerators Experts
gbob59
Dale Copeland
Dale Copeland
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
