Question about Numatic Henry Bagged Canister Vacuum
How do i bypass pcb board on a henry numatic international"?"
Posted by Darren Smith on
Andrew Deck
    New Friend:
    Problem Solver:
  • 12 Answers
You will need to remove all the wires off it and off the hi/lo rocker switch. Then disconnect to two wires on the opposite side of the on/off to the power in side. The two white motor wires then get connected to this switch. The machine will now run on high speed only when turned on.
Posted on Apr 06, 2017
  • Neal Sheridan
    Neal Sheridan May 10, 2019
    This, combined with a youtube vid, just helped me bring my poor dead henry back to life.https://youtu.be/v8JRGBhLD5U
5 Related Answers
Anonymous
SOURCE: Numatic Henry Hoover
They should just pull out with a little pressure and a pair of pliers. Good luck with your repair
Posted on May 28, 2008
Anonymous
  • 78 Answers
SOURCE: Numatic Henry Micro HVR-200
motor is over heating. you need to clean bag, filter and hose first then re test
Posted on Sep 05, 2008
Anonymous
  • 78 Answers
SOURCE: Changing my Numatic Henry hvr200 bag?
not really but should only look right one way
Philip Gaut
  • 389 Answers
SOURCE: numatic henry making a strange spluttering sound
Sounds like the carbon brushes in your motor are worn out. They can be replaced with new ones, but you may not feel like doing the job yourself. Best not to mess with electrics unless you are completely sure you know what you're doing... in which case, take Henry to a repairer. The job is simple, quick and should not be too costly.
Posted on Mar 13, 2009
kenharvey
  • 14 Answers
SOURCE: can i wash the filter on my numatic henry hoover?
If it is a recent model 2007 onwards, it may not be too successful, but you could try if absolutely necessary. Although not normally required, earlier filters can be gently washed by hand in a soapy solution, thoroughly rinsed and left to dry naturally.
Posted on Jun 08, 2009
HENRY VACUUM CLEANER HI LO SWITCH BROKEN CAN I DISABLE IT TO STAY IN HI MODE?
It can be disabled to stay in high mode, but you need to know what you are doing. It basically involves removing the small PCB and connecting the motor wires directly to the on/off switch. The hi/lo switch can be left in place (although not connected) or removed and a blanking plate put in it's place. You can leave a hole as this is a potential hazard and against government regulations.
Feb 28, 2015 | Numatic Henry Bagged Canister Vacuum
How do i bypass pcb "?"
Realistically this should only be done by someone who is capable of doing this kind of work. Electricity can be can kill if all procedures are not followed.
Jul 07, 2014 | Numatic Henry Bagged Canister Vacuum
How do i bypass pcb on henry numatic international"?"
you dont if you do youll blow up the motor as it will get 3000w and catch fire
Jul 06, 2014 | Numatic Henry Bagged Canister Vacuum
Henry hoover hi low switch
wtf you dont the wires are hard wired to the motor
Mar 15, 2014 | Numatic Henry Bagged Canister Vacuum
Disconnect PCB henry
Do you want to know how to bypass the pcb ?
Mar 12, 2014 | Henry Numatic "" Canister Vacuum
No power, electrical wirring is intact from power plug to switch to pcb
normally with a henry the cable breaks from where it joins the hoover just take apart from hoover end cut about a foot of cable off and then rewire
Feb 09, 2014 | Henry Numatic "" Canister Vacuum
New Henry Numactic Moter - How to wire?!
on the motor there are 2 connection together and one on it's own and on the brushes 1 each ignore these .and on the motor fix to the 2 tab one that you can see a wire connection on and then fix to the other side of the motor .this worked for me
Mar 11, 2010 | Henry Numatic "" Canister Vacuum
Aug 21, 2008 | Numatic Henry Bagged Canister Vacuum
May 21, 2008 | Numatic Henry Bagged Canister Vacuum
Numatic Henry Bagged Canister Vacuum Logo
2,032 people viewed this question
Top Numatic Vacuums Experts
Marvin
Marvin
Are you a Numatic Vacuum Expert? Answer questions, earn points and help others
