Question about Dual Audio Players & Recorders
I am looking for a face plate XDM6820 for a car radio.
Jonathan Wilcox
    New Friend:
  1. so who knows what kinda malware this site is spewing.
  2. But if ya still looking for a xdm6820 faceplate I recently aquired one in auction
  3. You still got the deck?
  4. july 06 2014 today is 3 18 2015
  5. Dallas Tx area
Posted on Mar 19, 2015
The face plate on my radio will not work
Check the connections on the head unit and the face plate. use alcohol to clean them. Look for a reset button, and check fuses.
Feb 17, 2014 | Cars & Trucks
How can i get behind the radio
the radio removal process does require a tool.If you look at the face of the radio,you will see a small hole in each corner,if you will take two large paper clips,bend them to where they are in a U shape,insert one clip on the left side of the face plate and the other on the right side of the face plate,and push into the holes at the same time.This will release the radio.
Feb 12, 2011 | 2006 Lincoln Zephyr
My xdm6820 has no display showing. What do you sugest? Any ideas? It works fine but can not see clock or radio station. No display at all!!
There are two 3mm white LEDs inside the face-plate that need to be replaced. Remove the face-plate and turn it over. Remove the 4 screws in the corners. Un-snap the plastic back off the face-plate. This exposes the back of the printed circuit board. Pull the volume knob off the front of the face-plate. You may need to use a small screw driver to gently pry it up. Flip the face-plate back over and remove the one screw that's holding the printed circuit board in. Separate the printed circuit from the front of the face-plate. Be careful to not lose the spring for the push pin. Flip the printed circuit board over and you'll see a raised metal box surrounding the display. The one end of this metal box is covered in black tape. Remove this tape to revel a small cavity in the side of the metal box with two 3mm white LED in it. These are the 2 LEDs that need to be replaced. This cavity is so small there's not much working room. Note that the positive terminal for each of these LED is on the left and the negative terminal is on the right. Rather than un-soldering the old LEDs I found it easier to use a small pair of diagonal cutters to just cut their leads and then pull them out of the cavity. Leave enough of the old leads sticking up to solder the new LEDs to. Trim the leads of the new LEDs to the proper length, slide them into the cavity one at a time and solder their leads to the stubs of the old leads. Make sure you get the polarity correct. Put everything back together and you should be good to go. I hope this helps you out.
Dec 20, 2009 | Dual XDM-6820 CD Player
How do i get the dash off to pull the old radio out
I'm not totally sure about the La Sabre, but there should be trim screws that hold the Dash face plate in place. There are three on the top portion of the face plate, and I think three on the bottom . The face plate extends from Light switch on left to radio on right. You may have to tilt the steering wheel column down to remove the face plate from around the steering wheel. From what I remember, the only thing that needs to be unplugged from the face plate is the plug for the rear defroster. Also, there are clips that hold the face plate in place. They just push in and out. Once the face plate is off, you can get to the radio mounting screws.
Aug 16, 2009 | 1993 Buick LeSabre
I have no display lights on my dual xdm6820 car radio. It does work but I can't see any words or graphics on the front of the unit. Can you tell me what is wrong?
if you have connected all the wires correctly you probably have a faulty dash,
If it is a removable face take it off and clean the terminals and re connect.
Hope this helps
May 07, 2009 | Dual XDM-6820 CD Player
My dual xdm6820 doesnt turn on and theres a red binking light behind the face plate next to the reset button
Probably you are mising 1 voltage,check this you need to have 2 voltages ok,1 voltage has to be present on the yellow wire(constant voltage,means all the time,ok) and the second voltage on the red wire (this voltage has to be switched wiht the ignition key)check this and try to fix the problem,probably there is a fuse blown,you can use a tester light to check the 2 voltages.or if you dont want to do this just conect the yellow and red wires together and the unit has to turn on.
Mar 24, 2009 | Dual XDM-6820 CD Player
1998 beetle radio buttons
The face plate buttons actually activate small buttons on a printed circuit board behind the face plate. When I removed the radio and then the face plate many small pieces of plastic fell from behind the face plate. These small plastic pieces align the face plate button to the printed circuit board buttons. My Beeetle is almost 10 1/2 years old so I imagine the plastic is just becoming brittle with age. I could not set the radio to FM, so I removed the face plate button and now slide a toothpick in the slot to toggle between FM1 & FM2. Not he best solution, but probably the most inexpensive one. I also made my on tool to remove the radio from a diagram found at: http://www.alientech.net/nbinfo/stereo.html
Jul 02, 2008 | 1998 Volkswagen Beetle
Adding a remote USB port
I solved my own problem.1 I removed radio1.gif face 2 I removed back cover of radio face to expose USB solder joints.3 I drilled a hole in the back cover of radio face over solder joints 4 I drilled a hole in front cover of radio behind face plate and lined it up with hole in back cover of face plate.5 I cut the male plug off of a USB extension cord and ran it through factory notch on the back of radio,through drilled hole on front panel of radio, thruogh drilled hole on back cover of radio face and soldered wires to back side of USB plug in. Wire colors from top to bottom are Red, White, Green, Black. Solder sheild to any of the three larger solder joints next to these connections. Make sure wires are not touching any other connections. Put radio back together and add screw that locks face to radio. Face can no longer be removed with this wire added. Now I can plug in my 8gb memory stick1.gif,hide it under the dash and have a clean looking installation.
Jan 17, 2008 | Kenwood KDC-MP435U CD Player
JVC KD -S680 needs help
all radios like your has two power inlets one is battery and the other is Acc or Ing. The battery line keeps power in the radio after you turn off your car both lines must work for the radio to turn on it sounds like a resister burn out thats why your face plate was warm.
Sep 25, 2006 | JVC KD-S680 CD Player
67 people viewed this question
Top Dual Audio Players & Recorders Experts
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
 Mikey
Mikey
Are you a Dual Audio Player and Recorder Expert? Answer questions, earn points and help others
