Question about Kenmore 24 in. 15689 Built-in Dishwasher
Door won't lock on kenmore ultra wash quiet guard 3
Caz Bowling
    New Friend:
  • 4 Answers
I would say it's worth getting a Professional to repair the door. It saves a lot of time and effort in the long run...and money! We had the same problem and no way could we have fixed it ourselves.
Posted on Jul 07, 2014
5 Related Answers
robert samples
  • 1314 Answers
SOURCE: Help
wow that could be a tough one there is no door lock on a dishwasher only a door latch what happens when you depress the door latch and can you send me a model number so i can pull up the blue prints and see if we can figure out a way to open it try pushing on the door and depressing the latch at the same time let me know what happens
Posted on Jan 10, 2008
Anonymous
  • 4 Answers
SOURCE: Kenmore ultra wash quiet guard 3 dishwasher problem
call sears, 1-800-4MY-HOME. They have a trouble-shooting department that will get rid of this problem. It is caused by water temperature being wrong at the start of the cycle.... blah, blah, blah. The representative will tell you to push a certain set of buttons in a certain order and that unlocks the dishwasher.
Sorry I don't know the sequence
Posted on Jul 01, 2008
drallim
  • 4088 Answers
SOURCE: ultra wash quiet guard standard kenmore. Little
Call Sears and have them honor their warranty.
Posted on Sep 26, 2009
Anonymous
SOURCE: Clean light is blinking. Services manual says:
No all you do is press
Normal-Wash, Heat Dry, Normal-Wash, Heat Dry,Normal Wash, Heat Dry, Normal Wash, Heat Dry
Then all the bottons light up
Don't press anything wait a few minutes and it will work again
I know because today we just had this problem and did this from looking it up online,
Posted on Nov 22, 2009
Anonymous
  • 523 Answers
SOURCE: My Kenmore Ultra Wash Quiet Guard
take kick plate off get book out how to reset board
Posted on Apr 24, 2010
My kenmore quiet guard My partially fills and therefore does not clean. any suggestions
Possibly low water pressure; possibly a clogged inlet screen on the inlet valve; possibly a bad inlet valve (replace it).
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Nov 14, 2014 | Kenmore Dishwasher With Ultra Wash And...
Why are there no lights on my Kenmore Ultra Wash Quiet Guard 3 dishwasher?
So I would guess you can't get it to work at all? It could be the circuit which is inside the door....I would never suggest anyone fix these things themselves. It's always fairly expensive but worth it for peace of mind knowing a job professional done.
Jun 25, 2014 | Kenmore 24 in. 15689 Built-in Dishwasher
Could you please help diagnose problem...dishwasher consistently stops washing in the middle of wash/sensing cycle. 2005 Kenmore Ultra Wash Quiet Guard 3
most likely the water is not hot enough,,it trying to heat the water,,when it starts to sense open the door and just test the water,,careful may be hot ,,but i doubt it...another easy way to tell is what is your hot water heater set on,,if you have a lot of soap residue is a good sign..
Sep 02, 2011 | Kenmore Dishwashers
Apr 24, 2010 | Kenmore 15899 Built-in Dishwasher
Soap dispenser will not open during was cycle.
Probably a faulty solenoid on the dispenser. Not replacable new dispenser needed
Jan 20, 2010 | Dishwashers
Loud Buzzing Sound from Dishwasher
have you ever seen green led "Clean" light flashing? before or about the same time the buzzing sound started? and if so that would indicate that the control senses a fault in the temperature rise during the heating cycle and that the electronic control could be reset by initiating a service diagnostic cycle.(which is what you were trying to do) pls reread your manual there are times during that sequence that some buttons have to be pushed at the same time and within a certain amount of time..possible that your machine also has a bad timer which would give you a buzzing noise..if thats the case I would recommend replacing the cpu or control board..or the machin all together..The Kenmore Ultra Wash Quiet Guard name is sears but whirpool has the contract to produce all "kenmore products.hope that helps.
Jul 30, 2009 | Dishwashers
How do I acess the control panel
Open the door and remove the top screws connected to the console. Close the door (not locked) and flip the console down toward you. Remove the control cover to gain access to the control board and the thermal fuse.
Mar 06, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
The IRONY of my Quiet Guard!! SO LOUD!!!!
Yes the wash arm can be removed to get to the sump area. Take the model number for your dishwasher and enter it into a site like partselect.com. There you can get a blown up diagram of the components that need to be removed to get to the cause of the grind noise. Usually a seed or some other hard object has found its way down there.
Feb 06, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Help
Jan 10, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore 24 in. 15689 Built-in Dishwasher Logo
328 people viewed this question
Top Kenmore Dishwashers Experts
gbob59
Marvin
Marvin
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
