Question about Bose SoundDock digital music system Docking Station for iPod - White (35703)
Bose instructions MY SOUNDDOCK IS SILENT NANAO WORKS IN MY CAR BUT NOT IN THE SOUNDDOCK
5 Related Answers
JK1993
SOURCE: No sound from Bose SoundDock
I had this problem on my SoundDock. My iPod would charge on the dock just fine and when I played my iPod on the dock, it would look like it was playing, but have no sound. Since my Bose was out of warranty, this is what I did to fix it. #1 Unplug the adapter. #2 Unscrew the four large screws on the bottom of the speaker and the three small screws under the dock. #3 You'll see one long ribbon connection and one very short one. Check to see if the ribbon connector coming from the front of the speaker system came loose from the green board. You'll only be able to see 1/2 an inch of it sticking out, and it's not easy to plug it back in, but it's possible. Just take your time. #4 Carefully put everything back together being very careful not to let the ribbon fall out of the plug again. #5 Make sure to plug in the DC adapter the correct way. There's a very subtle difference, but there is a difference. There are four prongs - two are square and two have slightly rounded corners. If it's not plugged in the correct way, the dock will have a static clicking sound. On my adapter, the words "DC power" are on the top of the plug.
Posted on Nov 24, 2009
Anonymous
SOURCE: docking cradle in bose sounddock
Order Prod Number 041615 , Description: "279103-004 MOD ASSY CRADLE BLK SOUNDDOCK" from Bose spares. Costs £35. Undo the four philips screws in base, romove cover and replace whole cradle assembly. There is a circuit board attached to the main unit by a ribbon cable - you do not need to remove this cable you can instead can thread the circuit board through the old cradle. Then pull out the ribbon cable that connects the new assembly to the circuit board. Installation of new one n reverse. Protect from static by using wrist strap etc.
Posted on Dec 03, 2009
Paul Curtis
  • 51 Answers
SOURCE: I need the Bose SoundDock schematics
No, but I have repaired many without a schematic. Aside from damage, there are abiot four basic failure modes. Tony
Posted on Feb 22, 2010
Anonymous
SOURCE: Bose Sounddock problem
I had the same issue, it just stopped working today for no reason. Since it's out of Warranty and Bose charges too much to fix it, I took the bottom off, cleaned all the contacts, applied some dialectric silicone compound to the contacts, put it back together... and it works great!
Posted on Mar 10, 2010
Paul Curtis
  • 51 Answers
SOURCE: Bose Sounddock won't play iPod touch
You probably have a broken docking connector or bad power supply. Contact www.invebo.com to get a replacement board. It takes minutes to fit. They also sell the USB charge upgrade to enable you dock to charge the IPHONE on the Soundock original.
Posted on Aug 16, 2010
Bose soundock 10
You want to plug the SoundDock into a 220 receptacle, is that correct, and the Soundock works off of 120v., correct. I tried to find the specs for the Bose SoundDock, i.e. its wattage rating but it seems that Bose does not publish these specs. At any rate a 220v to 120 v converter should work
The 300 watt converter listed above should work fine. Wahtever converter you use, make sure it operates at 60/50 hz.
May 19, 2014 | BOSE(R) SoundDock 10 Bluetooth dock...
My remote doesn't work. I put in a new battery; still doesn't work. Bought a new one from Bose.com, new one doesn't work. Am I doing something wrong? Do I need to reprogram or reset the Sounddock?
Had the same problem. I resolved it by removing my iPod from the dock and unplugging the SoundDock. I waited a few seconds and plugged the SoundDock back in. I then placed my iPod back into the dock.
I played a song and tried to use the right/skip button to skip to the next song. At first it didn't work. Then, I held the right button down for a few seconds. After that, all buttons worked just fine.
I hope this works for you. In case it doesn't, here is what the user manual says:
• Remove your iPod from the dock, wait five seconds, then firmly reseat the iPod in the dock.
• Try the remote from a different location. If it works there, check for interference from bright room lights or sunlight. Wipe off the small lens on the front end of the remote with a clean, dry cloth.
• Make sure there is a clear pathway between the remote lens and your SoundDock system.
• Remove and reinsert the battery as shown on page 6.
• Replace the remote control battery as shown on page 6.
Apr 22, 2010 | Bose SoundDock® (Black) Docking Station...
With my ipod dockes I am getting a distorted sound
Did you get this solved??
I am having the exact same issue!
Oct 21, 2009 | Bose SoundDock® (Black) Docking Station...
Sep 13, 2009 | Bose SoundDock Portable Music Pack Docking...
Bose sounddock remote and ipod menu functions
Unfortunately I've never seen a universal remote that will control the extra functions of this. If it's the original SoundDock, you can only do: volume, power, play/pause, skip/scan. If this is a SoundDock II or SoundDock Portable, you can only control: volume, power, play/pause, skip/scan, and playlist up/ playlist down. Quite honestly, that's all I need to do on my SoundDock. I can't really read what's on my iPod from where I'm sitting in the first place. It may be possible to use a universal learning remote for this, but you'd have to teach commands from an apple remote as well as the bose remote, and the learning remote (+apple remote) may cost you over 1/3 the cost of the SoundDock. It also may not work perfectly. I hope this helps somewhat.
Jun 22, 2009 | Bose SoundDock Digital Music System for...
Bose sound dock doesn't work at all
If this is the original SoundDock, the power supply in back is 4 pronged and a pin could be broken. If it makes a quiet thumping sound, then just make sure the power supply is not plugged in upside down (it's easy enough to do).
If this is the SoundDock II or the SoundDock portable, it's hard to say why this would happen, so you should call Bose on that one. There should be an indicator light that tells you when it has power..
Jun 19, 2009 | Bose SoundDock iPod Digital Music system...
When i plug in my sound docking station it makes a knocking sound
The only 2 possibilities are: 1. The power supply IS bad and needs to be replaced. (not the cord, but the supply itself) 2. The 4-prong power supply plug at the back of the SoundDock isn't connecting properly (try flipping it upside down, or making sure "DC power" is written on top if it's a later version.)
If this is the SoundDock Portable or SoundDock II, then the problem is definitely the supply.
Bose can send a new supply for $50+, or repair a non-warrantied SoundDock for $99.
Jun 13, 2009 | Bose SoundDock Digital Music System for...
Nothing happens
If you wanted to fix it you can look at ridax pcbs (if the connections are broken), but there a littleover $50+ for the part. But I'm currently buying broken sounddocks, so if youwant to sell it contact me at
Oct 02, 2008 | Bose SoundDock Digital Music System for...
Bose SoundDock digital music system Docking Station for iPod - White (35703) Logo
199 people viewed this question
Top Bose Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
