Question about Razor MX500 Dirt Rocket
How to test a qili charger - Razor MX500 Dirt Rocket
KX-TGA470-can charger be tested?
Yes. You can hook up a millimeter to it . It should read the same DC voltage that is print on the charger. If not then it's bad
Good luck
Mai
Jun 12, 2018 | Lands Phones
6530 aspire laptop charger gets really hot and doesn't stay charged for long
sounds like the battery is going bad on you . chargers will get hot when they have to work too hard as when the battery is not taking the juice .
Aug 03, 2015 | Aspire Computers & Internet
My computer shuts down when i plug in the charger
Assuming this AC laptop charger functioned correctly at one time. Several Possibilities: (1) laptop charger has failed ... connect another compatible charger to your computer to test for this; (2) or the battery has failed ... remove battery and test if the charger plugged in directly powers the laptop.
Apr 07, 2013 | Targus APA30US AC Laptop Charger AC...
My computer says plugged in, not charging
Dead battery. Test battery, try another cord/charger to verify.
Dec 01, 2012 | Toshiba Satellite A135-S4527 Notebook
Gateway solo 1450 laptop will not power up.
1. remove main battery and test with just ac charger.
2. test ac charger with multimeter or test notebook with good charger.
3. remove any memory, then test each stick once at a time in each slot.
4. if only 1 stick, get and test with a known good stick, in each slot.
5. plug into external monitor and then power on to test if its a screen issue.
6. clear bios - usually by removing main AND BIOS battery, wait 5 mins.
7. remove all hardware - hdd, odd, wlan, modem, etc and test.
8. remove mainboard, reseat cpu, benchtest
9. test power is getting past DC port - ie, DC port is not broken...
if fails on bench after clearing bios, reseating cpu, with different sticks of memory tested in each slot, with a known good AC charger, and dc port is undamaged, the board is faulty.
hope this helps.
May 19, 2012 | Gateway Computers & Internet
Charger problem how to identify
Hi, to identify charger. You will need to test another charger on the cell phone and test that same charger on another phone to confirm if the charger is working.
Also after testing for the charger and and if the charger works, that means the charging port of the phone where the charger is been inserted is damaged.
It will need to be fixed.contact you local repair person for help.
Take care.
May 22, 2011 | Cell Phones
Charger is not workking
Sometimes, the power supply to the charger might be too high or too low hereby resulting in damaging the charger. I will advice you test the charger on another phone before you conclude that the charger is bad. Once You have confirmed that. The only solution is to replace the charger. Once you have confirmed that the problem the problem is from the charger. Then You test the battery and the phone to know where the problem is from.
To test the battery,
  1. Power off the phone,
  2. Remove the battery,
  3. Insert it in another phone,
  4. Try to charge it with another charger,
If it charges, then it means the battery is working, but if it does not, then it means the battery is bad and need to be replaced.
Further test the phone,
  1. Insert a well tested battery into the phone,
  2. Plug a well tested charger into the phone to see if it will charge,
If it does not charge, then it means the connection port is bad and if it does charge, then it means the problem is not from the phone.
Before the end of the of the tests, You will have detected the problem and the solution to any of it is to replace it.
Hope this helped. Thank You for using FixYa!!!
Jan 12, 2011 | Samsung A501 Cellular Phone
Battery charger not working
make and model would help, general help do you have voltage tester? if so look at charger and find voltage output, test contacts and if lower than listed charger has gone bad, also clean all contacts with pencil eraser to make sure they are clean on battery and gun, if charger is good and contacts clean either battery is bad test in another device or test voltage, if battery good the drill is bad
Jul 08, 2009 | Drills
Razor MX500 Dirt Rocket Logo
154 people viewed this question
Top Razor Cycling Experts
Andrew Taylor
Andrew Taylor
ray gallant
STEVE
Are you a Razor Cycling Expert? Answer questions, earn points and help others
