If there is no power on both the drawers then 2 things
1. the circuit breaker on the mains power supply feeding the dishwasher has tripped
2. the power board that feeds the drawers is faulty. This is located at the base under the bottom drawer.
The drawers won't open because the power has failed mid cycle and the drawer seal actuator motors are locked in down position.
You can force open the drawers but this could require some mechanical adjustments to the actuator yokes if the two sides are out of alignment when power is restored. In any case you will have to force open the bottom drawer to get access to the power board. The part looks
like this but may not be the one specific to your model. You will have to contact a parts dealer local to your area.
The only reset function available is to turn the mains power off and back on.
Hope this helps. Please rate the solution if useful otherwise post a comment.
