Nikon D200 Digital Camera with 18-200mm Lens Logo
Question about Nikon D200 Digital Camera with 18-200mm Lens
I am unable to remove my 18-200 lens from my Nikon 200.
IMRAN HAFEEZ
  • 10 Answers
Press and hold the button on the left side near lens
move the lens to anticlockwise should release the lens
let me know if works, or if you have any more questions
Imran I am unable to remove my 18-200 lens from my Nikon - 1af763e9-b91f-4093-b3b1-abe4fe6e5d14.jpg
Posted on Jul 07, 2014
Nikon Coolpix p90 lens error 19
A "lens error 19" message on a Nikon Coolpix P90 camera typically indicates a problem with the lens mechanism and the camera is unable to extend the lens out of the camera body.
This error code could be caused by a number of factors, such as:
  • A mechanical malfunction of the lens mechanism,
  • A problem with the lens gears or the drive motor that extends the lens,
  • Obstruction in the lens barrel that is preventing it from extending properly,
  • A malfunction in the camera's firmware.
There are a few troubleshooting steps that you can try before seeking professional repair:
  • Make sure the camera battery is fully charged.
  • Turn off the camera, then remove the battery and memory card. Wait a few minutes, then reinsert the battery and turn the camera back on.
  • Gently tapping the camera on a flat surface to dislodge any dirt or debris that might be blocking the lens.
  • Use a can of compressed air to blow any dust out of the lens barrel.
  • If the lens barrel seems to be twisted, you can try to gently rotate it back into place.
If none of these steps help, it's likely that the camera will need to be repaired by a professional. It's best to contact Nikon customer service or a local camera repair shop for a diagnosis and estimate for repair.
Please note, opening the camera and tampering with the internal component can further damage the camera and will void any warranty it might have
1helpful
How do I fix my Nikon D80? It is flashing F-- and will not take pictures.
What lens do you have on the camera? The F-- indicates that the camera is unable to communicate with the lens. If the lens has the electronics to communicate with the camera, try cleaning the contacts on the back of the lens and on the camera body. If the lens is a manual lens, set the camera to the Manual exposure mode (turn the mode dial to "M").
Unable to rotate lens all the way for removal on Nikon D3000 SLR
take it to a repair center you may have forced it on the wrong way
there is nothing i can do but force it off.
Unable to remove lens - does not rotate completely
Did you press the lock/release button complete and did you hold it till the lens was rotated complete? You know the lens with Nikon goes the other way as with Canon?
Looking to the front of the camera you have to rotate the lens clock wise on a Nikon. Counter clock wise on a Canon.
Nikon D80 18-135 Lens, turned, remounted, cleaned contacts still will not turn on.
Call Nikon they will fix it for free if its under warranty
sounds like you went to a hack
1helpful
Nikon coolpix s630, lens error, blurry, ticking sound
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
1helpful
D90 - unable to shoot photo & remove lens from camera body
you must try to remove the lens that lens have some electric contacts and if you set the lens in wrong position that contacts give to the camera some error message
NIKON COOLPIX
The Camera displays lens error only when it's unable to retract or expand. This usually happens when the internal Hardware that controls the lens fails or any dust particle settles around the lens. In this case, just give slight bumps to the Camera against your palm. If the issue persists then service will be required.
Nikon d40 wont autofocus
Your 28-90 AF-D lens can't autofocus with the D40, which requires AF-S lenses with a focus motor in the lens. Sigma lenses with "HSM" (HyperSonic Motor) in the name also have the focus motor.
I am unable to take pictures. The LCD screen works fine and i am still able to get to the menu's. I beleive there is something wrong with the lens.
It seems defective CCD Imager problem in camera.
Since you have not mentioned Nikon camera model so I'm unable to provide you specific help for this black-screen issue.
You can click on Nikon Service Advisory page to check your camera model there and related Nikon advisory. Nikon offers free of cost repair facility for models in advisory list.
Top Nikon Cameras Experts
Steve
David Shaub
Are you a Nikon Camera Expert? Answer questions, earn points and help others
