Question about JVC Everio GZ-MG130 Camcorder
Why does my camcorder start up in japanese and have a vertical line through it sometimes
Posted by charlie musselman on
W.L.
  • 2,509 Answers
My guess is that the internal battery (not the main battery) is faulty and it has lost it's stored settings. Try changing it to English and keep it charged, don't let it deplete, see if it retains the setting. As far as the line is concerned, without a proper description its hard to say, but often bright highlights will cause a line down the display because of the way the imaging chip works, that is normal if it is only present with highlights
Posted on Jul 07, 2014
A white line has appeared on my desktop only
Two inch vertical line appeared.It sometimes is on the left and sometimes moves to the middle. It is only on the desktop.
Feb 20, 2009 | Microsoft Windows XP Professional for PC
Vertical lines
If the lines appear on the tape this way when it is recorded, then the CCD unit is going out on the camcorder. If it isn't recording the lines then the viewfinder wiring or screen is damaged.
You should problably take it into a camera shop to see if its worth fixing.
Aug 13, 2008 | Canon MV700i Mini DV Digital Camcorder
Blue vertical line on the LCD/EVF/Tape
If this camera is 4-5 years old or more, you need to replace its Capacitors, may be all Elecrolytic Capacitors.
Jul 31, 2008 | Panasonic NV-MD10000 Camcorder
GR-D33u vertical lines on all screens
you'll need to send it in for repairs.
some contact info for JVC.
Stacy Sample Service Coordinator JVC Service & Engineering 10700 Hammerly, suite 110 Houston, Texas 77043 (713) 935-9331 Ext. 101 [email protected]
being a fact that JVC camcorders are very trouble prone, it would probably be a better ideal & cheaper to buy a new camcorder.
for your next camcorder purchase, i would stay away from anything made by JVC.
Apr 13, 2008 | JVC GR-D33US Mini DV Digital Camcorder
Unable to view or record video
i fear you have a bad CCD. replacement of the same may rectify the problem.
Oct 08, 2006 | JVC GR-D33US Mini DV Digital Camcorder
Vertical lines
This is a defect in the CCD ( light sensor ) - check with Canon and they'll replace it free of charge even if the camcorder is out of warranty.
Jun 16, 2006 | Canon MV600 Mini DV Digital Camcorder
While lines problem
There's nothing wrong with your camcorder. This sometimes occurs when there is a lot of contrast between the background and the subject or object you're shooting. Try shooting from a different angle or adjusting the lighting conditions.
Sep 06, 2005 | RCA CC-432 Camcorder
JVC Everio GZ-MG130 Camcorder Logo
49 people viewed this question
Top JVC Video Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
