Its a fuser code. To reset it the code and to get it work again. Follow these steps:1) Turn the main power off ( the switch behind the toner door )2) Hold down the Utility button while you turn the machine back on. Jul 12, 2017
PrintCopy .info
https://printcopy.info > code=C3423
Code: C3423 · Description: Fusing heaters trouble (pressurizing side) · Remedy: 1 Check the fusing unit for correct installation (whether it is secured in ...
The C 3502 error code in Konica Minolta c 6100, 1100, 1085, and 6085 machines is related to the fusing unit. The error code indicates that the fusing unit is not heating up correctly. There are several reasons why this error code might appear, including a malfunctioning thermistor, a broken fuser heater lamp, or a damaged fuser thermostat .
Turn off the machine and unplug it from the power source.
Remove the fusing unit from the machine.
Check the thermistor and fuser heater lamp for any damage.
Replace the damaged parts if necessary.
Reinstall the fusing unit and turn on the machine.
If the error code persists, it is recommended to contact a Konica Minolta service representative for further assistance
The error code C0202 indicates paper jamming in tray 1, C-O204: Tray-2, C-0206: Tray-3, C-0208: Tray-4. First of all, power off and unplug your copier, then empty paper from the problem tray and from the tray below it. Take out the problem tray, now you can see a paper jammed.
Jun. 26, 2017 - Hi all I have the C0206 & C0208 when connecting the PC-410 (twin cassette) ... jonbonse is offline ... Konica C224 error C0206 & C0208 ...
Code: C0208; Description: Tray 4 Elevator Failure - The Lift-Up Sensor is not unblocked even after the set period of time has elapsed after the paper lift up ...
Missing: Mita. ' Must include: Mita.
