Question about HP PSC 1610 All-In-One InkJet Printer
How to repair hp colour laserjet print cartridge problem
5 Related Answers
Anonymous
SOURCE: HP Color LaserJet 2600n
Called HP service today as I had a similar problem......and I was out of warranty....but they said this happens at times if dust get into the top of the printer and they have a recall on them because of that.....they are shipping me a repolacement....FREE of charge.
Posted on Dec 04, 2007
Anonymous
  • 188 Answers
SOURCE: hp psc 1510 - only want black ink
Hi Manavoc,
I will explain you the cause for it.
It prints in yellow first and then override with black for better quality. This is the reason your color ink gets empty.
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c00308490&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Have a great day!
Posted on Mar 25, 2008
dapidc
Dapid Candra
  • 118 Answers
SOURCE: hp colour laserjet 4600dn, 51.2Y error...how to solve that?
From Woody Friesen:
Did the printer have a rough ride? HP's service manual suggests this to be a laser error on the yellow laser scanner, though these printers usually withstand shipping without any problems. Just for grins, if you can get the printer to get to READY again, run the printer through a complete calibration (from the control panel: Configure Device/Print Quality/Calibrate Now). The DC controller circuit board is also a possibility, but given the error code popped up almost as soon as you plugged the machine in suggests the yellow scanner has suffered some sort of mechanical damage from the trip. If the calibrate routine doesn't remedy the problem and you want to be sure, you could do the major disassembly required and swap the yellow scanner with the scanner for another color in the printer and if the error code changes to 51.2M (magenta), 51.2C (cyan) or 51.2K (black) (the code will reflect which scanner you exchanged with the one in the yellow position) you'll have confirmed the scanner is the problem, or if no change, then the DC controller is next in the chain.
Posted on Dec 24, 2008
Anonymous
  • 21 Answers
SOURCE: HP Deskjet 54280 won't print
Try cleaning the print heads. You can find more troubleshooting info in the manual:
http://h10032.www1.hp.com/ctg/Manual/c01374711.pdf
Posted on Jul 06, 2009
PrintDocta
  • 217 Answers
SOURCE: HP 1600 Colour laserjet Double image
Colour registration problem (some printer loose their registration from time to time).
There will be an option somewhere in the menu system of the printer, or the HP 'Toolbox' to correct this.
Posted on Aug 30, 2009
My printer is hp laserjet cp 1515n. After printing some documents it writes "printing cool down mode" and begins working very slowly. Please help me
1515n - I have the Magenta colour 'shadowing' the blue test. A mirror image of the blue text. [slightly staggered] Black is fine. Applies to all Word docs when printing in blue - can you help please?
I only use genuine cartridges.
Thanks
Jules Radstock
Jul 23, 2010 | HP LaserJet CP1518 Printer
My Hp color Laserjet won't print unless all
You have to replace all empty cartridges...no other solution
Oct 19, 2009 | HP Color LaserJet 3500 Printer
Hp color laserjet 2600 n it will not let me print
There is an override sequence and it works well. Press the select button (checkmark) to indicate Main menu. Press right-arrow (RA) to select System Setup. Press Select , then RA to Print Quality, Hit select. RA to Replace supplies and hit Select. Now, RA to Override Out and Select. Confirm with Select again. Your 2600n will now run even with an empty toner cartridge.
Jul 08, 2009 | HP Color LaserJet 2600n Printer
Large black strip printing problem
There is issue with cartridge drum change that drum (It's in blue or green colour). the second option is change the cartridge.
Your issue will be fixed.
Nov 30, 2008 | HP LaserJet 1020 Printer
HP colour cartridge no. 22 won't print
if the test pages come out OK then the problem can not be the printer !!!!!!!
it must be from the application
Sep 04, 2008 | HP Color LaserJet 2600n Printer
Why is it printing only black? I have a 12A Q2612A cartridge installed
This printer is a MONO laserjet printer meaning it can only print in black colour.
If you want a fax/copy/printer that does colour you would need something like a HP Colour Laserjet 2840.
Feb 19, 2008 | HP LaserJet 3050 All-In-One Printer
HP PSC 1610 All-In-One InkJet Printer Logo
efs_perpends
efs_perpends
k24674
