It currently has windows xp i want to replace it with windows 7
Sony does list Windows 7 drivers for this machine. but to be certain download and try this utility from Microsoft. http://www.microsoft.com/en-us/download/details.aspx?id=20. If this says you're good, you are. It will also show you what upgrades in both hardware and software may be needed for Win 7 to run properly.
SOURCE: I need drivers for the sonvy vaio PCG-6F1L!
That is because the actual Sony model is VGN-S360.or VGN-S360P You should be able to verify it. The model nember is not on the bottom it is on the RH LCD hinge. I do not think you can download the drivers anywhere but you can try:
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNS360
or just buy aa set of recovery DVDs from Sony
If you have the VGN-S360:
http://servicesales.sel.sony.com/ecom/accessories/web/viewItemDetail.do?operation=getItemDetail&itemID=537841&searchOperation=modelSearch&searchText=VGNS360
If you have the VVGN-S360P then
http://servicesales.sel.sony.com/ecom/accessories/web/viewItemDetail.do?operation=getItemDetail&itemID=537842&searchOperation=modelSearch&searchText=VGNS360P
SOURCE: pcg-7m1m sony laptop windows xp drivers
i want to download all drivers for sony vaio laptop pcg-7m1m
SOURCE: i need a driver for
You can download the device drivers from the Sony WEB site.
Select your model notebook and the Windows XP or Vista drivers you require.
Please click on this link to the Sony support WEB site :-
http://esupport.sony.com/US/perl/select-system.pl?PRODTYPE=1,24,72&DIRECTOR=DRIVER
SOURCE: how can i retrieve my
Hello seltiel_alle
Use your recovery disc . If you don't have one or if it fails , Xp is gone for ever .
If you are currently under Windows 7 Ultimate , or Pro , or Enterprise , you can download and install a virtual version of XP . You can get it from here : http://www.microsoft.com/windows/virtual-pc/download.aspx and it's free .
SOURCE: my sony vaio pcg-xg29 asks for a password i dont have it uses windows 98
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer Windows Advanced Options Menu Please select an option: Safe Mode Enable Boot Logging Start Windows Normally Use the up and down arrow keys to move the highlight to your choice select safe mode with command prompt Click start run type cmd press Enter black screen should open DOS mode this will vary depending on your operating system type in net user username For eg. If you want to change administrator password , type net user Administrator it will prompt you to enter the new password restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer Reboot the computer As the computer is booting repeatadly press the F8 key as the computer is booting If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu Safe Mode Enable Boot Logging Start Windows Normally Use the up and down arrow keys to move the highlight to your choice. select safe mode with command prompt Then type at the C:\> prompt: type Youll notice the password is gone. if this fails try typing At command prompt type debug if this fails you will need to Select safe mode with networking to download you could download all of these or just one save them to a usb drive for later use if one fails to remove the password Windows Password Recovery Basic http://majorgeeks.com/CmosPwd_d239.html A CMOS BIOS password recovery tool Editors note: This tool should only be used by experienced computer users. Please see the enclosed read me if you would like to run it from Windows. Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus.
Safe Mode with Networking
Safe Mode with Command Prompt
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Reboot
Return to OS Choices Menu
enter the new password and the password is changed
if this fails
Enable VGA mode
Debugging Mode
Reboot
DEBUG
and hit Enter. You'll see a dash (-) at the DEBUG prompt. Now type:
o 70 2e
which will show as -o 70 2e at the DEBUG prompt. Hit Enter. Then type:
o 71 ff
and hit Enter. Finally type:
Q
and hit Enter one last time to quit DEBUG back to the C:\> prompt.
Now you're ready to reboot your PC, and press the appropriate key or key
combo (look it up in your motherboard manual if you don't know it) to access
your BIOS Setup.
you will get a - prompt where you can type the following (<enter> means press enter, not type enter*)
A <ENTER>
MOV AX,0 <ENTER>
MOV AX,CX <ENTER>
OUT 70,AL <ENTER>
MOV AX,0 <ENTER>
OUT 71,AL <ENTER>
INC CX <ENTER>
CMP CX,100 <ENTER>
JB 103 <ENTER>
INT 20 <ENTER>
<ENTER> just hit enter on this line
G <ENTER>
Q <ENTER>
Basic BIOS password - works 9.9 times out of ten
hope this helps
