Question about Kenwood VR-606 Receiver
The subwoofer output on my Kenwood VR-606 has suddenly stopped working. I have tried the "setup" several times, turning the subwoofer off and back on. Also, when I first power up the system, it emits a low frequency hum, thru the speakers, for about 30 minutes. All of the other 5 speakers work fine.
Posted by Keith Spirson on
Don Wallis
    Scholar:
    New Friend:
  • 67 Answers
It sounds like the problem is not with your VR-606. If you hear a hum from the sub, the problem is more likely to be in the sub's built-in power amplifier. However, it is worth resetting the amplifier to factory presets. To do this, unplug the power cable from the mains supply and reconnect whilst holding down the power on/standby key. If the hum persists, connect any powered speaker to the sub-out socket, power on and listen for the hum. If no hum then suspect the powered sub amp. Turn the sub on with no connection to the Kenwood VR-606. If hum persists, the sub has a problem and will need to be replaced or repaired. By the way, you said there is a low frequency hum through the 'speakers' for about 30 mins. Is that all speakers or just the sub? Hope this helps.
Cheers, Don.
Posted on Jul 07, 2014
Have a Kenwood vr 606. The sub keeps shutting off. You can hear a relay click when it happens. A jiggle of the cord at the sub output will restore sound to it. I believe its a bad connection between the...
Hello Jason, from what you are saying, it would seem that the problem is inside the Subwoofer speaker, I do not think it originates in the Kenwood
Before you try changing the RCA-RCA cable between the Kenwood SubWoofer output and the Subwoofer speaker input
Also control the power cable of the subwoofer, if it is with an interlook, replace it
You have not commented that Sub you have, tell me the brand and model
If with these tests, you do not have positive results, take the Sub, to a specialized technical service
I hope you can solve this issue
Greetings Franco Dosil
Hola Jason, por lo que comentas, parecer?a que el problema esta dentro del bafle Subwoofer, no creo que se origine en el Kenwood
Antes prueba cambiar el cable RCA-RCA entre la salida de SubWoofer del Kenwood y la entrada del bafle Subwoofer
Tambi?n controla el cable de alimentaci?n del subwoofer, si es con un interlook, reemplazalo
No has comentado que Sub tienes, dime la marca y modelo
Si con esas pruebas, no tienes resultados positivos, lleva el Sub, a un servicio t?cnico especializado
Espero que logres resolver este tema
Saludos Franco Dosil
Kenwood vr606 reciever shutting off subwoofer and centre speaker simultaneously after few minutes/seconds of powering on. WHat's the cause?
The receiver's out put sections are grouped in pairs. Front left and right in one output, rear left and right in second output, and center channel and sub output on the third. Sounds like a semiconductor or semiconductors have gone bad in the center & sub output.
2answers
Cannot get the subwoofer to play...all other speakers work fine...my Kenwood receiver is VR-309...the subwoofer model is Kenwood SW32-HT... I have also used the setup mode to make sure the Subwoofer is...
After making sure that your subwoofer is receiving power, as most models have their own amplifier, make sure that it actually is turning on. There is a possibility of a faulty power switch. Lets rule that out first.
Once the switch is on and the proper power connection is verified, turn your attention to the setup menu on your receiver. Navigate to the LFE/Sub output level. Adjust it up all the way. Then navigate to the crossover setting. Turn it up all the way. If the subwoofer also has it's own control panel including a crossover, turn that up all the way as well. Then with an input on the receiver that has a subwoofer output set up such as for DVD, play some audio. Or likewise you can also use the receivers' test tone capability that will pan each channel individually with a wide band pink noise signal that also includes a signal sent to the subwoofer output.
If this procedure does not produce results then send me a message including your subwoofer model and your observations of your systems' operation.
1helpful
I have a new Samsung 47 in LCD and Kenwood DVD purchased in 2005. I am trying to hook both up to get surround sound from my Kenwood VR-606. My signal is coming from a HD cable box. I'm using HDMI from the...
Without additional equipment it can't be done. As i see your VR-606 pure analog device, and you trying to somehow use 5.1 sound from HD STB that is on HDMI put on RCA connectors of your VR-606. It is impossible without converter from HDMI to Analog audio or something likethis, best way to buy new receiver with HDMI input and TV neither Receiver with HDMI out oportunity. Then you will have your home cinema. In your current setup probably you can play only with stereo from your stb.
How to connect my kenwood vr-606 digital audio to my tv... i tried to connect digital audio cable from my tv digital audio output to kenwood vr-606 receiver digital audio in and it's not working.. what did...
Your TV is NOT an audio source by itself. It's job is to make pretty visual stimulus for your eyes, not your ears. Everything IT hears comes from somewhere else like a DVD, BluRay, Cable Box, right?
Get the absolute best TV-related audio directly from the digital audio outputs of each source you're watching, not the TV.
1helpful
Kenwood VR-606 - No display
a VR 606 is a 5.1 unit and currently has a market value of under $100 (used fexcellent condition) would not be worth investing over $100 to replace a dead LCD screen.
Check craigslist for a deal on a used unit in your area.
Remember its buyer beware, people tend to think their outdated stuff is worth more than it really is. A good tool is to look up "completed" ebay listings for the model you are considering to gauge if you are getting a good deal.
There are also several websites that have market value info available but usually the require a fee and are usually used by pawn shops, insurance companies etc..
3helpful
3answers
Receiver standby light,no power
WOOHOO!! I fixed this issue... same problem as everyone else has mentioned... to reset the Kenwood VR-606 receiver, unplug the unit. Hold the power button down and while holding the power button plug the unit in.
Say a prayer...
Then press the power button.
My display isn't working, but my speakers are working, and that's really all I care about right now... good luck to others!
1helpful
No sound from my VR-507
My Kenwood1.gif VR-507 had been working great. I hadn't changed anything. I hadn't even moved it. It just suddenly stopped producing sound. It didn't just stop while it was on. I had turned it off and when I turned it back on, nothing. I tried running the speaker setup to see if it would output pink noise, I could hear the test sound, but I couldn't hear any audio from the TV or DVD player..
Help. :-(
Sub-woofer output not working
"Sub-woofer output not working" problem, and notify you when a new solution is offered.
Press the setup key on the front of the receiver
Select the subw setting
Move the multicontrol knob until the sub woofer is on
Turn off the receiver and turn back on- the subwoofer should be on
The operator manual can be downloaded on the web site--- free
http://www.retrevo.com/support/Kenwood-VR-507-Receivers-manual/id/480ag219/t/2/
VR-606 DTS won't work
All I can tell you is that "CD/DVD" must be selected as the source when using the optical digital input on the VR-606/616. I don't believe it needs more than one input (optical or coaxial) to output DTS sound, assuming the source is outputting DTS in the first place.
Kenwood VR-606 Receiver Logo
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Morne Olivier
 Francisco Mauricio...
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
