How to read bar code
So i want to read bar code manally any help?
Posted by Aaron Zhang on
Charles Karcher
    Sergeant:
  • 213 Answers
Posted on Jul 06, 2014
Cannot read bar code
If it will not read any bar codes, then it must be repaired. If it only reads selective bar codes, then perhaps the one you are trying to scan may not be of the type it recognizes.
This scanner will read the following codes: LS 1004/LS 1006: UPC/EAN, Code 39 full ASC11, Code 128, Code 93,
Codabar, Interleaved 2 of 5, Discrete 2 of 5; LS 1000: undecoded
Mar 09, 2015 | Symbol LS-1006 (ls1006i0001900z) Handheld
Tip
How do I read Barcodes in Microsoft Excel?
<p>Bar code symbols are composed of a number of adjacent bars and spaces of different widths of pre-defined codes. A barcode scanner is used to read or scan the bar code symbol to represent the information to decode. Once the symbol is scanned by a handheld reading device or another, can then be used by computer software to track inventory and perform other functions. Microsoft Excel is a computer application that use bar code information can make the business perform. <br /> <p><br /> <p>1. Insert bar code scanner to your computer using the "interface cable keyboard wedge". The keyboard wedge interface cable looks like the printer port of your computer, and differs only in that a connection between the scanner bar code and serial number of your computer or USB port. The cable is provided as a peripheral pattern with hand-held bar code scanners. <br /> <p><br /> <p>2. Open Microsoft Excel on your computer after the bar code scanner connected to your computer. <br /> <p><br /> <p>3. Links on the Excel cell to the bar code to enter and bar code scanning to load it into Microsoft Excel. <br /> <p><br /> <p>4. View the data in Excel file is translated into a vision of the bar code information. <br />
on Jun 26, 2011 | Computers & Internet
Tip
How do I add CR to Barcode Value?
<p>The primary purpose of bar codes is to encode the unique characteristics of numbers and letters can be in a format that machines can easily read. However, bar codes are read by people often also for this reason, the codes generally include both parties readable and legible. The most popular bar codes meet a standard called "Code 39". The latest version of the code with 39 additional characters called "Extended Code 39." Among other characters, Extended Code 39 allows users to include carriage returns (CR) in bar codes. <br /> <p><br /> <p>1. Setting the bar code scanner to read "Extended Code 39," Code 39 is not as common support CR. The details depend on the specific bar code scanning software is used, but you will usually find this option under "Tools" then "Options." <br /> <p><br /> <p>2. Configure the software to generate bar code to the "Extended Code 39" is also used. The details depend on the specific software to generate barcode is used, but you will usually find this option under "Tools" then "Options." <br /> <p><br /> <p>3. Type "M $" (without the quotes) at the point where you want the CR model is within the barcode. M $ gives a CR Extended Code 39. <br />
2008 honda rancher will not shift dash shows a blinking line or dash
the rancher will shift is u put a braker bar on the shiter to manal shift it... i had the same problem but there is a soilinod that needs to be clean or replaced its a constient problem with honda
Sep 10, 2013 | Honda 2008 FourTrax Rancher ES
Can a credit card be processed using a code bar scanner?
no, you can't. bar code scanner only read bar code. Credit card should read using swipe card reader (using magnetic to read code behind black strip on credit card).
Aug 10, 2010 | Computers & Internet
I WAS JUST WONDERING IF THIER WAS A WAY TO TELL IF SOMEONE WAS TRYING TO CONNECT TO MY WIRELESS.I HAVE A LONG LONG LONG PASSWORD AND SOME TIMES ITS BLINKING RED IN THE WIRELESS BOX.AND NO ONE HERE IN ON...
i really dont think so somtimes the belking 54 g will blink for no apparent resone but if your really bothered then you can easly change the wpa code (thats the 8 numbers or letters that is your wpa code for it) just a fast read of the manal will explain how hope this helps
May 15, 2010 | Belkin (F5D7230-4) Router (587009)
Ive got an ipod touch which i got today, on the screen shows a picture of the charging cable and says itunes above it, it wont do anything else apart from saying slide bar to switch off, can you help...
Just plug it into your computer and open up iTunes(if you have not downloaded iTunes, download it here). iTunes will have you go through a quick set up for your iPod. Then you should be able to get past the iTunes and charging plug screen.
Hope this helps!
Dec 25, 2009 | Apple iPod touch
Ip adress keeps timing out
bro you will need to change your wep code even if you know the correct one i think it is becuse it allows other devices or somthing to conecte through to change your wep code do the following
1 open internet broser
2 type in the bar (http://192.168.0.1) tuyp tthis in for D-link routers. for Netgear routers type(http://192.168.1.1) as for Belkin routers type (http://192.168.2.1) if you have a diffrent router you are going to have to shearch it on google.
3 ok now when you put in the routers address in the address bar and press enter this parssword/user name thing will pop up you will net to enter (admin) this is the defalt for most routers if you have a difrent router look in the instruction manal or somthing. if you have changed it and you can nto remeber it ring your brodband support.
4 ok now your in your routers seetings change your wep code then reenter the same thing on your psp.
ok some times this will not work and the (ip address thing has timed out) thing will be starting to really **** you off ok this is what you do.
5 go to the start botton in the bottem right coner and click on this then you will need to click on run let it pop up and in the bar type (cmd) this will bring the comarnd promt up if you have vista just go all programs then to asseories then the comarnd promt.
6 once you have ented in (cmd) click on enter and the command promt will pop up in there just type (ipconfig/all) then it will come up with a bunch of informatin on your router.
7 go on your psp and go to ip settings click on manal and enter in the settings that the command promt are telling you.
note: make sure you dont use yuor proxy setings this secrew up thes all way of doing it.
then you are all done and this should work!!!!!!!
Jul 02, 2009 | Sony PlayStation Portable (PSP) Console
Sim blocked on my motorola v551
if u ave the manal the puk code should be in the manal if not u can take it to the local phone shop and they will unlock it
Jan 20, 2009 | Motorola Mobility V551
I can't programmed my IT3800LR
Jaquino, there is a programming bar code to reset the device to factory settings in the user guide. I know you said that it is reading other bar codes like they are not programming bar codes, but have you tried this bar code? Usually it works, even when the device is totally hosed, unless there is some kind of hardware failure.
Here's the link to the Quick Start from the company website:
http://www.handheld.com/download.aspx?download=/data/f9e7f996-9ecc-4f49-b604-32fbd754085d.pdf&filename=3800+Linear+Series+Quick+Start
The factory reset bar code is on printed page 4 of the PDF document.
Mar 05, 2008 | HHP Hand Held Products IT3800LR-12 Barcode...
Televison & Video Logo
152 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
