SOURCE: Freezer leaking water
The drain is plugged just below the coils in the back of the freezer. My fridge had the same problem and I found the hose (which can be accessed from the rear bottom) was plugged with mold. Also, i noticed the hose was connected to the water holding pan and was too close to the bottom and easy to plug. I removed it from the connector and just let it dangle in the holding pan.
SOURCE: Ice maker is leaking small amounts of water.
Is the amount of water to much for the tray size , you can adjust it with the small screw behind the icemaker cover . is the line entering the back of the icemaker jammed up to far causing it to spray ? Or is the icemaker or refrigerator not level
SOURCE: Water collecting and freezing in bottom of freezer
Hi, Remove the rear inside panel of the freezer and locate the drain hole under the evaporator coil. Remove the ice and flush the drain hole with hot water to make sure it is free. You can try running a soft wire through the drain also.
I hope this helps you. Please let me know if I can assist you further.
Vic
SOURCE: Water building up on the bottom inside the freezer side
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freezer.
SOURCE: water is leaking in the
when the cold coil is freezing up this is caused by a failed defrost system ( a bad heater or terminator . or the aditive defrost control . it also will freez the drain in the back of the freezer and this will cause the water to end up on the floor . . i would defrost the frig and repl the terminator . the heate is usualy good . and if problem comes back then replace the a d c . // the a d c pt # 241508001 and the terminator 5303918214 . this is a very common problem .. mm hope this helped and thanks for using fix ya ..
