SOURCE: Washer will not leave the drain cycle
ok let me pull up the servic manuel and ill get back to you ok we are all trying to help but takes time ok
SOURCE: Door wont unlock
Try "end of cycle" button, & wait for a couple of minutes before u try the door; do not force door.
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
SOURCE: F22 Error Code
TAKE 3 SCREWS OUT THAT HOLD THE BOTTOM FRONT PIECE REACH UP BEHIND AND ON THE DOOR LOCK MECHANISM THERE IS A ROUND PLASTIC DOOHICKEY PULL IT DOWN ABOUT 1/2 AN INCH OR AS FAR AS YOU CAN AND IT WILL UNLOCK THE DOOR. I WOULD UNPLUG UNIT FIRST. I DON'T KNOW ABOUT THE F22 THING. MY JUNKER DOES THE SAME THING PERIODICALLY, I UNPLUG AND REPLUG IT TO CORRECT
SOURCE: whirlpool washer door won't secure
Do you mean that the door won't lock, or that it locks, but requires an extra push and hold to make things work. If the latter, find the finger in the door area that trips the interlock switch and extend it's length slightly with hot glue or epoxy a small piece of wood or some such.
SOURCE: Door locked on compact Whirlpool front-load washer
This worked for me. I turned off the washer and hit the area on the washer directly to the right of the door handle (not hard enough to break something or cause a dent). It popped right open.
