Question about Hotpoint Aquarius WF220 Front Load Washer
What does a 5 year guarantee cover
I have a repairman coming to fix the drum bearing during the week. However if he cant fix it, or reports that he can't fix it, I have to buy a new machine. I understand its not an easy job so he could just say that it wasnt repairable. Couldn't he? And why should I have to get a new machine if it's still under the 5 year guarantee?
Posted by Carol Ni Bhearain on
1 Related Answer
Anonymous
  • 639 Answers
SOURCE: Hotpoint WMA32 drum problem
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
This machine in three years ago in the UK cost 280 pounds
You probably can buy it today for half the money from then!
I suggest a new one and not that model which had a lot of problems! Speed Queen has the best warranty.And does 8 loads a week for 25 years.
They start at about $549 in the States!
Not sure if they sell it in the UK????
Here is a good service that I recommend to my customers,
in our 65 year old appliance business! they answer 24/7
Not expensive!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Aug 26, 2008
Kenmore elite quiet pack 9...was whisper quiet when it was given to me about 8 months ago, now it is very loud during spin cycle sounds like a jet taking off how do we fix it?
Either the inner drum support has broken..Or the rear bearing (Which means replacing the complete rear half of drum #8 as the bearing is part of the drum) is worn..Last but not least could be a broken shock.The inner drum support is what the pulley in back is connected to..It is welded onto the back of the inner drum..What happens is the support breaks loose..Which will cause what you described..You would need to remove the drum then split the half's to inspect...Before doing this..Remove the back cover..And inspect the shocks.
Apr 25, 2012 | Washing Machines
The machine made a horrible sound during spin cycle. I thought it was a belt that had broke. But we took the back off the belt is ok but it look as if the drum had come off the springs. We took a crow...
Unfortunately, the repairman is probably correct. If the rear tub bearing goes bad on these washers, or if one of the spin basket drum supports breaks, it usually requires the replacement of the internal spin basket. One simple test you can do yourself is to open the washer door and place your hand inside the drum at the 12 o'clock (top) position. Push straight up and release. If there is any play in the drum, this usually means one of the rear spin basket supports has broken, or the rear bearing is bad. Unfortunately, the only way to make this determination is to take the washer part and remove the outer drum shells. If the spin basket supports are intact, the drum bearing is molded into the rear drum shell. The bearing usually is not removable, which requires the replacement of the entire back shell. This is a maintenance intensive repair that usually takes a trained technician about 2 hours to complete. Even if you attempt the repair on your own, the spin basket alone costs over $300. The rear tub shell (with the bearing) is about $345. You may try contacting the manufacturer to see if there is a warranty on the spn basket. You can use the following link to see what warranty informaiton may be available on your appliance:
http://www.sears.com/shc/s/nb_10153_12608_NB_CSwarrantyinformation?adCell=W3&i_cntr=1292622625154
It has been my experience that overloading the washer can contribute to the premature failure of the bearing and drum supports, however, there have been some cases where the spin basket supports prematurely failed due to poor welds or corrosion. These washers are usually very reliable and should last many years with proper care.
I do not necessarily agree with the repairman's assessment on the drain pump, however. If the drum slipped off the support mount springs while running, the washer would not have completed the cycle and would have shut down. This would have left any water that was already in the tub unable to be drained. If the tech performed a diagnostic test AFTER the drum was put back in place and the water still would not drain, there should have been an error code present on the front panel display of either "F02, F21, or "SUD".
If you have any questions, please post back and let me know.
Dec 17, 2010 | Whirlpool GHW9200L Front Load Washer
Hi my hotpoint washing machine is near 3 years old the last few weeks it is making a terrible noise when on spin only. \r\nthe noise is really loud but everything is washing and drying the same its just...
Sounds loike the main drum bearings have failed.
Spin the drum by hand from the front, and if it feels rough, or is rumbling or grating, then the main bearigs have failed.
Quite an expensive repair, unless it is covered by the Hotpoint 5 year parts guarantee, check with Hotpoint.
Jun 16, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Our Kenmore Elite Oasis that we purchased over 3 years ago started to make incredible noise during the spin cycle, so loud you can barely hear yourself think. We had a repairman from a Service Company...
Yes, Sears repair just ordered one for mine. Entire tub due to bearings gone. Also just over 3 years old and ext warranty ran out in June. Final inspection before warranty was scheduled in June 2010. July the bearings are gone. Hmm wonder how they missed that? Anyway if you call for service, ask about the maintenence plan. Its way cheaper than labor and tub and u have another year for more issues with this piece of junk washer.
Dec 01, 2009 | Washing Machines
Drum shakes during spin cycle
I have a 7 year old duet washer. It started to shake during the spin cycle. It is level and the shocks and springs holding the drum are working. When the washer gets to the spin cycle, it is apparent that the drum is off center.
I tore the machine apart and found that there is a bracket at the back of the drum. This bracket sits in water so it was covered in slime. I found several large cracks in the bracket. Once these cracks occur, there is now way the drum can spin correctly. The bracket is welded to the back of the drum, so it has to be completely replaced.
What a poor design. I would guess that many, many other people will be seeing the same problem within a couple years. I was lucky in that I did not pay for a repairman to try to fix it.
Oct 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Similar problem...repairman said the bearings were gone though
The repairman is correct. The drum support(aluminum alloy) has deteriorated and is crumbling to pieces.
Aug 21, 2009 | Kenmore 43142 Front Load Washer
Loud banging noise during final high speed spin
I have the HE3T which is 6 yo. Last week it started making a loud banging noise in the spin cycle. I had a repairman come out. He said it is the drum bearings. He said that it is a problem with these machines and to call Sears. He said that the drum and bearing is one assembly and that Sears should cover it.
I called today and Sears todl me that I have to pay for a Sears technician to come out a determine if it is indeed the problem. If so, it will be covered under the lifetime warranty on the drum. I have to pay for the service call $75.00 and if it is the problem, I will be reimbursed. Cross my fingers!
May 21, 2009 | Frigidaire ATF6000ES Front Load Washer
THANK YOU!
Same problem here and Ge refuses to fix no charge it is clearly a recall sitition they are trying to avoid the drum is out of round on ours only 1 1/2 years old smoke was actully coming out of it does someone have to have a fire b-4 it is recalled ( or how Many fires will it take ) Very unsafe !!!
Dec 28, 2008 | GE Energy Star WCVH6260F Front Load Washer
Heat on drum won't turn
if the drum is not turning its the belt its not hard but can be a pain for a beginner a repairman would charge at least 150 dollars to fix. It would only take him about ten minutes to do.
Dec 20, 2008 | Estate Dryers
Squeaks from drum area during operation
Hi there!
I think it is the drum main bearing that has started to sieze.
If it is not this, then the drive belt may need replacement.
If this leads to a solution, please take a moment to accept. Thank you.
Jun 18, 2008 | Bosch Nexxt WTMC 3300 Electric Dryer
Hotpoint Aquarius WF220 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
Eric Taylor
Richard C Cohen
Richard C Cohen
Onofrio Taverna
Onofrio Taverna
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
