Question about Samsung SyncMaster 204B 20.1" LCD Monitor
How to change samsung syncmaster S20B300 screen colour
3 Related Answers
Rudra Aradhya
  • 99 Answers
SOURCE: problem in samsung syncmaster 793MB is that when
hi,
I think there is problem with your display card.
If you could try testing with another monitor you ll get confirmed. In that case you have to purchase another VGA card and install it then it works fine.
Regards
Posted on Oct 03, 2009
Anonymous
  • 5 Answers
SOURCE: My model : Samsung SyncMaster
Good Morning!
One thing that I have noticed when I change settings on my monitor is that sometimes it needs to be re-aligned. Thankfully this is very easy to do. There is a button on the bottom right of the screen that says "Auto". dantheman286.png
Press this button and you should see the screen shift and become sharper.
If this does not work, you may want to change the monitor back to the default settings. You can do this by navigating through the menu: Press the Menu Button -> Select "Setup" from the on-screen menu -> And then separately select "Image Reset" and "Color Reset".
Please feel free to comment back if this does not solve your problem.
Thanks!
Posted on Mar 01, 2011
Edde Jenkinson
  • 53 Answers
SOURCE: HI I have a samsung
The VGA cable you are using might not be seated correctly. Try removing it and replacing it.
If you have another monitor, can you see if that also goes green when you use it with this computer?
If all monitors go green when used with this computer then your problem is with the computer.
If the problem follows the cable, then the cable is the problem.
If the monitor stays green with a new cable on a new computer then the monitor is the problem.
Posted on Jul 27, 2011
Thin vertical colour lines on half of the screen
Hello, there is a problem with your monitors picture tube. May be it might have been damaged as a result of over power or even because of over use. Just try to change the picture tube or change your Monitor.
Nov 15, 2017 | Samsung SyncMaster 910MP 19" LCD Monitor
My model : Samsung SyncMaster 940bw After change of setting, I am getting images which are not clear and crisp and having less colour content
Good Morning!
Thanks!
Mar 01, 2011 | Samsung Syncmaster 940BW LCD Monitor
Samsung syncmaster 2433bw , suddenly went out of colour. Tested it with a ps3 but I found a setting that shows me colour .. its the dynamic option under magic colour
Samsung Sync Master 2433BW has the brightness rectangule and monitor menu in one corner of my screen. How I disable/remove that rectangul?
Oct 21, 2010 | Samsung SyncMaster 910MP 19" LCD Monitor
Problem in samsung syncmaster 793MB is that when shaked,colours change but when unshaked,screen is green or blue.is there any solution to this?
hi,
Regards
Oct 03, 2009 | Samsung SyncMaster 793MB 17" CRT Monitor
My monitor's color is mixed with the color yellow
There is an option on the monitor to reset colour to factory default. Just bring up the on screen menu by pressing the left most button at the botton. Use the button next to this to highlight the colour settings which I think is the 5th or next to last option down. You will then see the option to reset colour and various other factory default settings. Happy computing
Jul 21, 2009 | Samsung SyncMaster 940N Flat panel Monitor
Monitor colour problem
the VGA cable connecting from moniter to the computer is faulty so replace new
May 25, 2009 | Samsung SyncMaster 793MB 17" CRT Monitor
Problem with samsung syncmaster 540N 15"
To replace all Electrolatic capacitors in Power supply& drie Currected
check all connectors are properly connected r not
Sep 13, 2008 | Samsung SyncMaster 540N 15" LCD Monitor
Focus on monitor
Try replacing the filter capacitors on the video circuit.
Apr 28, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Samsung SyncMaster 204B 20.1" LCD Monitor Logo
140 people viewed this question
Top Samsung Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
ThaMp3Doctor
ThaMp3Doctor
Marvin
Marvin
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
