it is either your proccessor or your memory is bad find a plce that will check for free if they are good then your disply or vidieo chip is bad and the chip cant be replace but if it is the display then you should be able to connect it to another type of disply
Hi, Press Info / Display button on TV remote, on-screen display will disappear. Sony TV Remote is required for that function, other remote wont work. Thanks.
Your display circuit is broken, even if the LCD-panel,
seems to be ok the display is damaged.
This is a very common problem in Nokia phones.
The only way to fix this is to change the display.
You need a T-5 or 6 Torx Skrewdriver to do the job.
You can find displays for fair price at :
www.mytrendyphone.com
This is your solution! Please vote!
hi..the reason for ur problem is the
display button.There is a display button
available on the top next to the power button.
Make sure that the display button is turned on,
if ur display button is turned off,ur displayscreen
doesn't appear.It will look black.
check this out..
thank u..
yes you first check the supply at vertical ic 12v if present then replace that vertical ic if supply is not present then check the regulator ic in smps if faulty then replace it
right clcik on the file u wish to delete and then go to properties and then make sure the check button on READ ME is unticked so u should see no check at the Read only box and then u might be able to delete it or tht error message appears when u have deletd the file alreadyand it still shows thoguh thry refreshing it and hopefully its deleted
