SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
REFORMAT USB ON IMAC - SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
My imac won't detect my usb keyboard
try other usb device to rule out functioning usb port. try kb on different mac, try different usb port
Imac G5 USB panel
Try eBay, lots of iMac spares, you might be lucky.
I have a blue my passport but either lost or never had directions for installing it on my IMAC. How do I start?
IMac Have USB ports and your WD hard drive comes with a USB cable. Just connect to one of the USB ports of IMac and you are set. IMac reads and formats to Mac OS
I just bought a new Imac computer. I had a Maxtor One Touch 4 500 GB that I used with my windows xp. What if anything do I need to do to...
The drive will need to be reformatted to the HFS file spec for Mac. You will lose any data on the drive when you do that.
However, you shouldn't need to do anything other than plug the drive into your iMac, then once the icon appears on your desktop (may take a minute), double-click on it to start the Mac install process.
If the Mac install process fails for some reason, it may be because the drive was previously installed on a Windows machine, and you may have to simply treat it as a "raw" new drive, and reformat it using the Mac operating system utilities.
Hope that's helpful.
Iomega 1TB HD Works on iMac but not on Windows Laptop?
as the mac has a diffreent format to a pc you cannot connect up the drive to a pc because it simply wont recodnise it. the best way is to network the 2 computers together then alow file sharing on the mac and searcc with windows through the network to find the drive. then copy them across the network to your pc. this will then reformat the files to PC files at they hit your PC
Memory Stick Pro Duo says it's full when not - photos to iMac
move the auto install file then reformat the flash drive as fat.
Formatting
Inside the iMac or as an external drive? If internal: Use the OSX Installation disk
Airport Extreme 802.11g
At this point you are much better off installing a USB wireless antennae than spending money on an Airport card, cracking open the iMac, and installing it.
USB wireless adapters are cheap, plentiful, and have more capabilities than the generation of Airport cards that were made for G5 iMacs.
1helpful
Top SanDisk Computers & Internet Experts
Steve
Marvin
Marvin
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
