Question about NetGear Computers & Internet
Cannot connect 192 168 0 1
I need to change the password
Avneet Bhulania
    New Friend:
  • 14 Answers
Reset it .
Under the hood there is a reset button , keep pressing it for 3-5 seconds.
Posted on Aug 11, 2014
How do I set password on Wi-Fi orca android tablet
Answer Line: Change your Wi-Fi password on various ...
www.pcworld.com/.../change-your-wi-fi-password-on-various-...
PC WorldFeb 11, 2013 - But Wi-Fi passwords, like every other kind, need to be changed every so often. Here's how to ... Android. You can't simply change the password here; you'll have to delete the network from your phone or tablet and recreate it.Missing: orca
How to Connect Your Android Tablet to a Wi-Fi Network ...
www.dummies.com/.../how-to-connect-your-android-tablet-to-a-wifi-net...
After you've activated the Android tablet's Wi-Fi radio, you can connect to an ... ... Be careful when connecting to a non-password-protected network. It's possible ...Missing: orca
How do i change my wifi password [Solved] - WiFi - Cell Phone ...
Dec 14, 2015 | RCA 8" Android Tablet w/Dual Tuner
Tip
How to change your wireless network password. Forgotten wireless password.
Hi. Thanks for looking!
Due to the fact that many questions are being asked about routers and wireless networks I decided to put little tutorial together .
· How to change my routers password (forgotten password)
Since you forgotten your password and can not connect to wireless network you will need an Ethernet network cable in order to connect to router.
Before doing anything else switch your computer on and make sure that your router is on also.
1.
Connect Ethernet cable to your routers free port at the back and the other end to your PC/Laptop network port.
Once you get confirmation that you are connected to the network (you should notice this in the task bar right lower corner of the screen)
2.
Open your internet browser and type 192.168.1.1 in the address box and press enter. If this don'ttake you to the site asking for username and password please do the following.Click Start and choose run (below search) type "cmd" in the box and press enter.This should start a command prompt where you need to type in "ipconfig" and press enter. This should show you information's about your network. Default gateway address will be an address that you need to type in your browser box.
3.
Once you get to the login page, provide your username and password. You should be able to find this in your manual for router but if you can't you can find it hear--->click hear.
4.
Please note that since there's so many router vendors instructions in step 4 may vary, but these are basic.-
When you logged in to your router settings page please find wireless tab and choose security. Get to the password box and change password to whatever you like.
5.
Remember to save changes before quitting. Now unplug your cable and try to connect to your network wireless, using your new password.
Bravo! You just completed password change.
password change,no password, router password, router settings, no key, no connection, wireless password
on May 05, 2010 | Computers & Internet
My Kobo Arc 32, asked for a password, when I tried to try the WiFi. I don't remember setting a password. So, now it's asking for an guest password.
It is not the Kobo that has set the password, rather the router for the wifi that you are trying to connect to. You just need to know the password for the router to let you connect. If a router has no wifi password, it is considered unsecured and ANYONE can access it. So most all routers use password protection. If it is YOUR wifi system, and you no longer know the password, you can change it if you access the router setup for wireless and change the password. Be advised, however, that all devices that connect to the wifi will need to change their passwords as well or not be connected. If it is not your wifi you are trying to connect to, then you need to obtain the wifi password from that wifi system's administrator.
Nov 06, 2015 | Tablets & eReaders
How do i change the password so people can't connect other than me?
The category is listed as Network and Wireless Adapters, but the question is leading to an answer regarding routers. The router in a network is what allows connection and assigns IP addresses. The router uses encryption and a security passkey (password) to allow uses to connect. You would need to log into the router using the administrator ID and password, go to the Wireless page and change the access password. ALL USERS would then need to reconnect using the new password.
Oct 30, 2015 | NetGear Computers & Internet
Want to get my Cisco guest password
Open Cisco Connect then click Guest access. The password is displayed under the Password header.
To go to the Guest access option using Cisco Connect, follow the steps below:
Step 1: Select Guest access at the main screen of Cisco Connect
In the Guests access settings window, you can enable or disable the Allow guest access, change and check the password for the guest network, or change the number of Total guests allowed.
NOTE: The Guest network name is the main network's SSID with -guest as a suffix. If you want to change the guest network's name, you will need to change the main network's SSID.
Dec 29, 2014 | Cisco Linksys E1000 WirelessN Broadband...
Need to reset password on a Belkin d80
To restore it to the factory settings press a paperclip into the hole marked "reset" for 5-10 seconds. Do that wile the router is on. Then if you need to set a special password you can connect to it and change the password.
To change the password connect to your router by going to your browser on your computer after connecting to your router. The default address for belkin is usually "192.168.2.1" for login its either "admin" or just left blank. there shouldn't be any password. After you login you can go through the settings and change your wifi name and password. Most routers also have many other security options like only allowing certain computers on that you add their mac addresses. Hope this helped. If you need more help just leave a comment.
Feb 11, 2014 | Belkin (F5D7230-4) Router (587009)
I need to change my password on my speedtouch dialup connection
To Manually change the dial up password in Windows 2000 or Windows XP -
Go to your Start, Programs or All Programs, Accessories, Communications, Network and Dial-Up Connections
- Select your connection
- Enter your new password exactly as it was given to you in the password box
- Be sure the Save Password box is checked
- Click Dial to connect to connection with your new password
- Your new password will be saved when you successfully connect to connection
- Be sure to save your new password in a secure location
Dec 07, 2011 | Microsoft Windows XP Home Edition English...
I need to change my password on speedtouch dialup connection
To Manually change the dial up password in Windows 2000 or Windows XP - Go to your Start, Programs or All Programs, Accessories, Communications, Network and Dial-Up Connections
- Select your speed-touch connection
- Click Dial to connect to speed-touch with your new password
- Your new password will be saved when you successfully connect to speed-touch
I have problem setting up my wireless network and redirecting my wireless client to my local webpages before they can access to internet.   see this diagram below :...
you need to replace your modem with a router that is capable of running Network Address Translation. You are trying to route private IP's (192,168.x.x) over the public IP (internet) network.
Jan 31, 2010 | Microsoft Windows 2000 Professional for PC
I want to change the default password to make my connection secure. I cannot dispaly 192.168.2.1 page to change it
is it an website password for your site,, or else an dialup connection password,, you need to change
Sep 27, 2009 | Belkin Computers & Internet
Open Questions:
Netgear Router Customer Service Phone #@[+1-844-33O-233O]@ Number USA Netgear Router Customer Support +1-844-33O-233O for Netgear Router Customer Service Phone Number via Helpline Toll Free Number Netgear Router is known for offering different astounding administrations including ...Netgear Router has ranked the list of reliable and widely used among all other Antiviruss. As being the technical equipment these Antiviruss are vulnerable to failure. But no matter which model of you are using Netgear Router customer support number will provide assistance and guidance for every issue confronted by you in any model of this . We Tech are remote Netgear Router support service provider for Password recovery phone.Look Tech at your Technical for Repair , for customer phone number labeled as Customer Serial phone Number,to repair Serial No, technical. Netgear Router created and circulated by Netgear Router Technologies, provides malware obstacle and removal throughout a subscription phase. It uses unique signatures and heuristics to recognize viruses. Additional features comprise e-mails spam filtering and phishing safeguard.support It proficiently takes care of all types of malwares, together with all computer viruses, computer worms, computer viruses, adware, Netgear Router Tech Support And Help Center Contact Phone Number Trojan horses, and spywares etc. Netgear Router at one point covered 50% of the US marketplace and still it is known to be one of the most trusted all across the world. Malwares are the most hazardous bugs for the computing world.
Dec 03, 2019 | NetGear Computers & Internet
Computers & Internet Logo
130 people viewed this question
Top NetGear Computers & Internet Experts
Mike
efs_perpends
efs_perpends
Lee Hodgson
Lee Hodgson
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
