Two, and in conjunction with #1, the blade guide on the left side of the blade may need to be brought closer to the blade ( but without actually touching).
Three, is thee any blade damage that could be pulling the blade to the left? Try another blade and see what results you get.
If you need help determining if one or more of these issues are the problem you're experiencing, or if you need help making the adjustments, you're welcome to send photos of your machine and I can walk you through it.
Everything sounds and looks good but the cut is uneven. I would think the only possibilities are a freewheeling blade, or an upside down blade. Neither situation is rare. If neither of those is possible I think I would set the whole thing up on jack stands and make sure nothing is going akilter in the mechanism which raises and lowers the deck, one side could be hung up.
Is the exhaust clear all the way out? Unplug the range and see if the problem goes away, if so you may have a control problem that is keeping the fan operating at a very low speed. Good Luck, Gilshultz
For now, it works only satisfactorily:
I applied alcohol to further clean both blades,
dried and then oiled them. There seemed to be a slight gap between blades;
the fabric was dragged into the gap instead of being cut.
