Question about Mercedes-Benz Vehicle Parts & Accessories
Mercedes key fob button jammed
The button on the fob will not press but is hammed
richard vreede
    Sergeant:
  • 432 Answers
Can you pull it up a bit by two tiny screwdriver and try to lift it a bit and move it left or right.... were the sleeve is, but it's offcourse a sign of wear, so replace it. Gr richard
Posted on Aug 16, 2014
Why are my key fobs not working on my 2006 Chevy Monte Carlo XLT?
To better answer your question it helps to know if the key fobs worked before and just stopped working, or if you bought a new key fob.
If you bought a new key fob you must program it to your vehicle. Here are the key fob programming instructions for a 2006 Chevy Monte Carlo:
NOTE: 2O11 & newer vehicles must be programmed by an automotive locksmith or dealership.
PROCEDURE #1
THIS PROCEDURE IS FOR VEHICLES WITH THE DRIVER INFORMATION CENTER. IT WILL BE A BUTTON TO THE RIGHT OF THE STEERING WHEEL WITH A VEHICLE ICON AND THE LETTER i.
  1. Insert key and switch the ignition ON (just shy of starting vehicle without cranking engine)
  2. Press vehicle information button until PRESS TO RELEARN REMOTE KEY is displayed.
  3. Press the set/reset button (button will have a check mark) until REMOTE KEY LEARNING ACTIVE is displayed. Vehicle is now in programming mode.
  4. Press and hold LOCK and UNLOCK buttons at the same time on first remote for approximately 15 seconds. An acoustic signal will be heard indicating successful programming.
  5. Repeat step 4 to program additional remotes. You can have up to 8 programmed remotes for this vehicle. You must program ALL remotes including existing remotes.
  6. To exit programming mode turn ignition OFF, remove key and test all remotes.
PROCEDURE #2
THIS PROCEDURE IS FOR VEHICLES WITHOUT THE DRIVERS INFORMATION CENTER.
  1. Insert key into the ignition and turn to ON (Just shy of starting vehicle without cranking engine).
  2. Press the trip odometer reset button until RELEARN REMOTE KEY is displayed.
  3. Press and hold the trip odometer reset button for approximately 3 seconds until REMOTE KEY LEARNING ACTIVE displays.
  5. Repeat step 4. to program additional remotes. You can have up to 8 programmed remotes for this vehicle. You must program ALL remotes including existing remotes.
If your key fob worked previously and it just stopped working here are a few key fob fixes to try:
Change the battery
Batteries don't last forever, you'll be surprised how often it's just a dead battery! Search our YouTube channel on how to change a key fob battery for your specific year, make, and model!
Wipe the board
The board inside your remote can get a lot more filthy than you think! When the board is dirty it can prohibit the contact to the circuit board when you push down on the button. Simply wiping the circuit board off can make your key fob like new again!
The old car battery reset trick
I know this sounds absurd, but it works sometimes and is worth trying. If you exhausted all of the options above, disconnect both terminals on your car battery for 10 minutes. Then reconnect them and try your key fob. This has worked for many people and I have no idea why.
t might be time for a new key fob! No need to dread over the expensive costs of a new key fob, at Keyless Entry Remote Fob Inc., you can get a refurbished one for a very affordable price! You won't even be able to tell the difference. Just search your vehicle make, model, and year to purchase a key fob or give us a call at 402-671-5100.
Oct 16, 2015 | DSC Wireless Key Fob
Key fob wont re set on my ssan yan rexton
I recently changed the battery on my key fob for my ssanyong rexton. I then did the following for the key fob to make it work. 1. Enter vehicle and close all doors.
2. Put seatbelt on (or clip it into the buckle) to shut the warning buzzer off.
3. Put key in ignition, turn to run position but don't start it.
4. Press and hold both buttons on key fob until red light on fob stays on. Then let go of both buttons. Then pressed the alarm button then the panic button, somthing like that. To be fair the button sequence after the red light came on is a bit vague. The alarm was blaring so i was happy when it just stopped.
May 23, 2012 | SsangYong Rexton Cars & Trucks
Crimestopper SP501 car alarm/remote starter will not respond. The 2 way one doesn't work, the sidekick does.
You need to program your crimestopper sp-501 key fobs, you need to program both the 2-way and the 1-way key fobs, during the same key fob program session. First find your valet button/switch, when you have found it, turn your ignition on and press the valet button four times, if you have a toggle type switch for a valet switch, toggle it up and down four times, when its in remote key fob program mode, it will honk your horn 4-times followed by 4-parking light flashes. Once your have done this press the lock button on the 2-way key fob, horn will honk and the 2-way will sing a little song to confirm programed, then press the lock button on the 1-way key fob the horn honk will be your confirm programed. turn ignition off this will exit you from program mode. then shut all doors and test key fobs for operation functions....hope this helps you out
Dec 03, 2011 | 2006 Hyundai Sonata
Sorry my car was not listed so picked Altima 2003 Micra Intelligent key fob not working properly. Can drive the car but cannot open or lock the doors. Did get fob wet. Now dried out. Worked for first few...
You are going to need to check the power lock control moduel on the inside of the door panel. If the FOB appears to be working but the doors are not unlocking, you need to check this. I would also replace all fuses that control the locks. If both of these devices check out ok, you may need to replace your FOB. To check your power lock control moduel, manually lock and unlock your doors by pressing the lock button on the inside of the door. If it does not work, it is either the fuses or the power lock control moduel. If it works, your FOB has gone bad. Hope this helps! Please rate 4 thumbs up!
Apr 18, 2011 | Nissan Altima Cars & Trucks
Press the key fob button and the tone goes for about a min.
A door is open or the body ecu think is open, when you press the open button in your fob make sure the open door indicator in the cluster if off, also make sure that the buttons in your fob are not sticking
If you need further help, I’m available over the phone at https://www.6ya.com/expert/flavio_517b938f50183b92
Dec 24, 2010 | 2000 Toyota Camry Solara
Keyless entry remote programming
Hello here is the instructions for programming the key fobs
This procedure will add, replace, or invalidate all key fobs. This procedure requires that you have a known good key fob available, a new/replacement key fob, the vehicles mechanical key, and a scan tool.
Method 1 is also used for the initial programming of fobs to a new replacement RCDLR. In this instance, the new RCDLR comes ready to learn the first key fobs introduced. Perform the learn procedure as outlined, with the exception that the new RCDLR does not require a known good key fob be placed within the interior of the vehicle.
Note: This procedure is not available when the maximum number of fobs (4) have been programmed. If 4 key fobs are programmed to this RCDLR and this method is attempted, the driver information center (DIC) will display MAX FOBS LEARNED and the programming procedure will exit. Methods 2 or 3 must be used in this instance.
  1. The vehicle must be OFF.
  2. Place a known key fob and any new/replacement key fob(s) to be programmed in the cupholder inside the vehicle. DO NOT place any fobs in the console fob pocket at this time.
  3. Insert the vehicle key in the driver door lock cylinder located in the driver door handle and cycle the key 5 times within 5 seconds.
  4. The DIC will display a message: READY FOR FOB X (X = fob 2, 3, or 4). → If the DIC displays: OFF/ACC TO LEARN, the known fob has not been recognized. At this time, programming will revert to Method 2.
  5. If the DIC is displaying the correct fob number that needs to be programmed, skip ahead to step 9.
  6. If the DIC is not displaying the correct fob number that needs to be changed (i.e., the DIC is displaying: READY FOR FOB 3, and you wish to program FOB 1), use the scan tool to access the following: • Vehicle Control Systems • Computer/Integrating Systems • Module Setup • Remote Control Door Lock Receiver • Program Key Fobs
  7. Select the fob position you wish to program: Note: Selecting Invalidate All Fobs will erase any known fobs and will cause the DIC to prompt READY FOR FOB 1, requiring all fobs to be relearned to the vehicle.
    • Invalidate All Fobs • Program Fob 1 • Program Fob 2 • Program Fob 3 • Program Fob 4
  8. With the fob position selected, press the PROGRAM soft key on the scan tool. The DIC should display: READY FOR FOB X (X = fob 1, 2, 3 or 4, depending on the selected position)
  9. With the DIC displaying the correct fob position that is to be programmed, place the new/replacement key fob in the console fob pocket with the buttons facing forward.
  10. A beep will occur once the fob has been learned.
  11. If programming additional key fobs and there is no DIC prompt that indicates READY FOR FOB X, repeat steps 7 and 8.
  12. Exit programming mode by pushing the OFF/ACC portion of the ignition switch. Note: Failure to exit programming mode (press OFF/ACC) prior to pressing the UNLOCK button of each key fob programmed will result in that fob being inoperative. Pressing the UNLOCK button completes the programming sequence and is require to ensure transmitter operation.
  13. Press the UNLOCK button on each key fob that was programmed to finalize the programming and confirm system operation.
Nov 03, 2010 | 2006 Cadillac STS
Having problem with the beeper for my honda pilot 2004 its not the bateries can't open the dors with beeper..
In the case the battery was drained in the keyfob - try reprogramming it.
Here are the instructions.
The process is pretty easy....1st) get in the vehicle and close all doors, windows, hood, and trunk.
2nd)put the key in the ignition and turn it to the second position...while in that position (w/out starting) push the lock button on the good key fob you already have. (if you don't already have a good fob, then press the lock button on the new key fob) (do this all w/in 5 seconds)
3rd)turn the key off
4th) turn the key on to the second position and press the lock button on the fob.
5th) turn the key off
6th) turn the key on to the second position and press the lock button on the fob.
7th) turn the key off.
8th) turn the key on to the second position and press the lock button the the fob.....the press the unlock button on the fob..........Now press the lock button on the new fob...press the unlock button on the new fob....
9th) tun the key off.....remove the key from the ignition and test to make sure that the new fob and the old fobs both work now.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 06, 2010 | 2004 Honda Pilot
Resetting a Key fob on 2007 Honda Pilot
to program a key fob- get in vehicle and close all doors. insert key into ignition, have all the key fobs you want to program for this vehicle in hand, programing erases all old fobs. turn the ignition switch to on(all dash lights light up, on click before starting the car). then hit the lock button on one of the fobs. turn the ignition to lock. turn the ignition back to run and press the lock button again from the same remote. repeat untill all the locks cycle. ones the locks cycle keep the ignition in run and press the lock button on each key fob(the ocks will cycle each time a button is pressed). then turn the ignition to lock after all fobs have been programed
Dec 31, 2009 | 2009 Honda Pilot
Key fob wont work on my Peugeot Expert
Does the battery need changing on the key fob?
you can check by using you'r mobile phone cam & pointing the key fob (ultra violet bulb) at the lens when pressing the button, you should see the light flashing on the key fob looking through the camera, you can use any camera, most of them will see the light as it's out of our sight range but cameras pick it up.
If not then unscrew the key fob & split it carefully (use an old credit card not a knife or screwdriver) & change the battery.
If the fob work's then the problem is with the receiver, usually up by the rear view mirror.
Hope this help's !
Sep 21, 2009 | 2005 Peugeot 405
Key fob will not undo cetral locking or disable car alarm changed battery in key fob still having no luck any idea who can re code key fob to central locking and alarm?
If you don't have one that works for the vehicle now, you'll have to take it to your local dealer to have it programmed to the vehicle. Some will charge for this, some will do it at no charge.
If you do have a remote that is programmed and working for the vehicle, then the following steps will allow you to program another remote:
4. Press and hold the unlock button on the working key fob and hold for 4 seconds, then also press the panic button.
5. Release both buttons and you should hear a single chime to indicate it is in program mode. You have 30 seconds after the chime to program any additional remotes you want to program.
6. Press and release both the unlock and lock buttons simultaneously on the remote you are programming. You should hear another single chime.
7. Within 4 seconds after hearing the chime, press either lock or unlock button on remote that you are programming.
Oct 16, 2008 | 2001 Chrysler PT Cruiser
Vehicle Parts & Accessories Logo
Top Mercedes-Benz Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Bill Boyd
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
