Question about Frigidaire ATF6000ES Front Load Washer
Why wont my maytag neptune dispence softner - Frigidaire ATF6000ES Front Load Washer
Cant get it to use softner out of dispencer
if this is one of the newer(less then 3 years old) it probably has a button on the control panel that will say fabric softener. it will only flush the cavity out if you push that button. if it is an older model then the fill line for the softner cavity is brobably clogged
Apr 24, 2010 | Maytag EPIC MFW9700S Front Load Washer
Maytag neptune tl fav6800aww wont dispense fabric softner
Test mode? Do you mean Service Mode and you turn on the solenoid for the water valve to divert water to the Fabric dispenser reservoir and it is flushed in Service Mode?
See if this solution will help with your trouble shooting.
Let me know if I can help……Rich
Apr 19, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune Washer model # MAH9700AWW will no longer despense fabric softner,
yes the cup that the fabric softner goes into the cap of it is called the syphon. poor water in the cup and go over the max line does it syphon the water?
Jan 30, 2010 | Maytag Washing Machines
What does the code suds mean on my maytag neptune washer
sud's ( like to much soap ) this causes the machine to shut down . mix some downey of fabric softner in a quart of water . pour it in tank . let set over night . and try again . fabric softner will get rid of suds or at least reduce them . it will probably work .. mm
Dec 08, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Maytag neptune washer is dispensing fabric softner during wash cycle! help!
not good. the board usually tells the dispenser to activate and send water to you fabric softner, ive seen two different problems on the maytags, your water valve could be bad or clogged or the board is bad.
Sep 17, 2009 | Maytag Washing Machines
Maytag MAH8700AWW will not dispense fabric softener
u need to replace the water valve theres 2 the cold is what u would replace
May 21, 2009 | Maytag MAH8700AWM Neptune Front Load...
FABRIC SOFTNER DOES NOT DISPENCE
Check to make sure the litle cups are set in place correctly and also make sure they are not blocked with hard fabric softner. A quick test: pour water directly into the fabric sofnter cup and fill it up,IF it siphons out, you will need a new inlet valve for that unit. The inlet valve has soliniods on it for the bleach & fabric softner.
Good Luck!
Feb 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water pouring from detergent, bleach, etc.. dispencer. Help!
This is joyce
He is right the Jets are probl stoped up with mold,
you need to take drawer out look to top of machine where water comes into drawer to dispense to your detergetnt, and see if their is mold, if so take squirt bottel full of bleach and squirt it up on the mold and let sit a while and then take tooth brush and scrub off as good as possible, run one cup bleach in machine with out any clothes . on hot cycle. do this 2 times see if this helps .
let me know. it can only help cant hurt.
willl make machine smell better, and never shut door to front loader completly shut, it needs air to dry or else it will mold.
thanks
joyce
Feb 11, 2009 | Maytag MAH8700A Front Load Washer
My neptune washer will not drain the fabric softner container
This is joyce
I have advice for you check the siphon cap to see if its twisted reposition cap.
thanks
joyce
Jan 17, 2009 | Maytag MAH6500 Neptune Front Loading...
Frigidaire ATF6000ES Front Load Washer Logo
46 people viewed this question
Top Frigidaire Washing Machines Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Poppa Maddo
Poppa Maddo
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
