When i pushed the power button, nothing happens. it appears that the battery will not charge. what can i do?
SOURCE: Dell Latitude D600 won't power up
Dell power jacks are notorious for losing the solder connections. If all else fails remove the motherboard, use a solder wick and remove the old solder and resolder the connections. There are four pins that are close together so you need to make certain you do not over solder. Hope this helps
SOURCE: green battery charging light flashing and computer won't start
Have you tried removing the battery and replacing it again?
SOURCE: C500 Laptop won't come on power button just flashes
Have you tried attaching an external monitor when the LCD screen is disconnected from the motherboard? this connector is located under the keyboard strip – a piece of plastic just above the keyboard.
If it works, this way, then the video cable isn’t seated properly in the connector on the back of the screen.
Plugging the video cable back in should fix the problem.
I don’t know how comfortable you are with taking apart laptops but I think that this information could be useful for you.
Source: http://www.asklaptopfreak.com/laptop-notebook-help/2006/08/08/laptop-powers-on-and-shuts-off-immediately/
SOURCE: Compaq C500- Will not turn on
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
SOURCE: my lenovo T400 will not start up
I got the same problem. Have u resolved the it? If so, please send a message to: [email protected]
2. Remove and Reinsert Battery
In some situations the battery can become loose. Removing it and then put it back into the laptop.
3. There is Some Software
Use battery utility to determine the total capacity of the battery. For example, Battery Care Software is a free software utility capable of doing this.
4. Refreshing Battery
Some laptop manufacturers allow for batteries to be refreshed through the CMOS setup.
If problem still there. try Replacing Battery or Power Adaptar.
still the problem persist take the laptop to Service Center
best of luck..
