Question about Mitsubishi WD-60735 Projection Television
TV keep turning off and my red lamp light comes on
bobalix
  • 471 Answers
Some projection TV have a high temperature switch that opens if the lamp enclosure gets too hot. Check back or TV for any grilles or openings that may have gotten plugged with lint or dust. Carefully vacuum out these openings to restore proper air flow this should reduce the temperature and may solve your problem.
Hope this helps.
Bob
Posted on Dec 13, 2014
Maryanne Mandarino Harp
    New Friend:
Red Lamp no longer illuminates and has
reached the end of the lamp life.
Replace the lamp. The TV will not operate when the lamp no
longer illuminates.
or you made need service for the tv..
Posted on Jul 06, 2014
5 Related Answers
Anonymous
  • 3130 Answers
SOURCE: Lamp Light Red - No Screen Image
It could be the a problem with the lamp ballist circuit, or just a bad lamp socket, or simply a bad lamp. The only way to tell is to call out a servicer as that would be alot less expensive then to get a new lamp and then that not be the problem. These problems can be a little hair pulling at times, thats why i have no hair left!! LOL Good Luck
Posted on Mar 21, 2007
Anonymous
SOURCE: screen is black
Same problem with model WD-Y57 (14month old). Can't find any dealer that sales the part at a better price then mitsupart.com
Posted on Jan 10, 2008
Anonymous
  • 50 Answers
SOURCE: Mitsubishi DLP - model #WD62725
you have mention that after 10-15 seconds T.V starts up, will you give total description of the T.V within that 10-15 seconds?
Posted on Aug 11, 2008
Anonymous
fixityrsel is wrong.
1 The "Airflow message"is just a bad connection and very easily solved.Mitsubishi has a service bulletin out and will cover the repair for free. Your set may not even have the defective connectors.
Your set was manufactured in 2004..Call any authorized Mitsubishi
servicer.
Capacitors are very easy to find! Any (105 degree) PC mount [email protected] 16VDC will work fine..and not bulge again..Higher Working voltage than the stock 10 VDC is what caused the problem with the caps.
Mouser electronic is one of hundreds of suppliers for those caps
Order online if you know for sure they are bad in your set.
Dan
Posted on Aug 14, 2008
Anonymous
  • 16 Answers
SOURCE: WD-52525 - No picture, green status light then turns to red lamp
check the lamp
Posted on Jun 26, 2009
What's your problem?The tv comes on for 1 second and turns off and the red lamp light is on
Replace the lamp. The red lamp light is indicating an issue with the lamp. You can get the replacement lamp with installation instructions from www.tvrepairworld.com
Oct 19, 2012 | Mitsubishi Televison & Video
I have Philips 50PL9126D/37 The red light on the front where the power indicator is keeps coming on. What does this mean? When it comes on my screen goes blank. Any suggestions?
The tv projection lamp in this tv been in the tv it like 2 years or more,tv in used daily like 4 or 5 hrs every day?The red LED light indicator is on,have a "LAMP"word written on the bazel frame?Yes,tv projection lamp life is over or eding.Tv reqire a new projection lamp.
Apr 05, 2011 | Philips 50PL9126D/37B 50" DLP TV
Power light keeps blinking Red and TV will not turn on
Is the light blinking constantly or is there a long pause then more blinking. If constant check the lamp door switch . Usually it is broken or jammed. If you jumper it and the set comes on that it. 4 blinks is bad fan.
Mar 24, 2010 | Sony Grand WEGA KF-42SX300 42" LCD TV
Win i turn the tv on the red light comes on and i can hear the tv like its comeing on but the green light comes on and cuts the tv off but it comes back on but it does the same thing
Your lamp could be burnt out. The tv will keep retrying to start for a few times then will shut down. remove the lamp and see if it looks burnt. When you replace it you will also have to reset the lamp timer. check your manual to see how to reset.
Feb 14, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
I turn the tv on it stay on for one second then it goes off thats when the lamp button comes on its red. then the red light comes on and it stays on although the tv is off the red lamp light is still on
Your lamp timer may be maxed out which means you should change the lamp and reset the lamp timer. When the timer max's out it won't turn on till it is reset.
Feb 09, 2010 | Mitsubishi WD62327 TV
THE TV PICTURE KEEPS GOING BLANK THEN COMES BACK ON ALL BY ITSELF. THERE IS A GREEN LIGHT FLASHING, NO RED LIGHT.
This is symptom of weak lamp in TV.
How old is this TV and did you replaced lamp recently?
If not, replace lamp in TV to fix this issue.
Lamp light does not lit solid if lamp is not broken or dead.
Lamp replacement procedure is easy and would written in user manual.
Thanks.
Jan 26, 2010 | Sony KDF-E50A10 50 in. LCD HDTV
Keeps turning itself off with a red light next to
have you changed the lamp in this set. If you look by the red light it probably says lamp
Aug 07, 2009 | Televison & Video
Tv wont come on
You may have a Lamp fan that is not turning. You can verify this shining a flashlight in the Fan Exhaust housing and see if it turns when you turn the set on.
Jul 17, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Mitsubishi WD-60735 Projection Television Logo
185 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
