Fisher and Paykel 24 in. DD603H W Built-in Dishwasher Logo
Question about Fisher and Paykel 24 in. DD603H W Built-in Dishwasher
How do I reset the f1 flood button . Dd603ss - Fisher and Paykel 24 in. DD603H W Built-in Dishwasher
Sam
  • Fisher and P... Master
  • 3,247 Answers
Not sure if you have managed to fix the F1 problem with your dishdrawer. This is a common problem and occurs mainly due to water leaking into the base of the dishdrawer under the bottom drawer.
But if it is occuring only in one drawer then the power filter at the base of dishdrawer is faulty and needs replacement.
Otherwise make sure the mains power to dishdrawer is turned off. Pull out the bottom drawer and stack in some towels behind it if you can to remove the moisture sitting on the base. The flood switch is located there. Then take a hair dryer and run it down behind the drawer to dry things. Push drawer back and turn power back on. Now if you cannot reach the back of the drawer then you will have to pull the drawer out from its rail. Refer the installation manual for this. See link page 7.
You need to find the source of the lead, Fisher Paykel DishDrawer Installation Instructions ManualsOnline com
Posted on Aug 01, 2014
5helpful
3answers
Dishwasher beeping and displaying F1 on screen. HELP!!
F1 error means that the flood switch has been activated. To reset the flood switch you need to remove the bottom dish drawer to be able to access the reset buttons. To remove the drawer you press in the rectangle buttons and slide them back under the drawer, they are located right behind the front panel at the bottom of the drawer. It may help to have someone help hold the drawer for you. Once they are slid back all the way place the bottom drawer on the floor to the left side of the washer as you look at it. This will give you the access you need. Lie down on the floor so you can see in the bottom. There you will see a white coloured plastic box on each side, one is for the top drawer the other is for the bottom drawer. Make sure the power is off to the dishwasher. Place your finger underneath the box and you will feel a small pin/lever. This is attached to the magnetic flood switch and resets it when you click it one way and then the other. Once you have done this turn the machine back on before you put in the bottom drawer as if it does not work then you will need to activate it maybe a couple of times. Once the F1 alarm disappears you are good to go. Place the drawer back in the opposite way to removal. Slide one rack forward and rest the drawer on it. Then slide the other side out and it will snap lock into position.
What does f1 mean
The F1 error refers to 'internal flood.'
You may wish to reset the power of the unit, this may clear the error code.
One common cause is too much or 'wrong' detergent causing too many suds. In this case, giving the unit time and a reset is all you need to do.
You may wish to check under the unit to look for a tray with a widget floating in it. If you find such a tray, empty it & cycle the power to reset the F1 error.
I hope that helps.
Disher washer is giving a signal F1 for repairs Model DD603SS
F1 means flood. Below is a link to a video that will show you how to fix the issue if you want to download the video.
http://www.appliancerepairlesson.com/shop/dishwasher-videos/fisher-paykel-dishwasher-repair/
Good luck
The backlight on Fisher and Paykel DD603SS has gone out
There is some reason the LCD needs to be reset. Un plug the cord. Remove the front panel, on the top right you will see the small circuit board. On the right of the circuit board there are a few connectors. Disconnect them all and leave for 30 minutes. Put it back then plug in the cord. It will work again. If not then it needs to be replaced. Unplug alone the cord didn't work for mine. Good luck
2helpful
2answers
2helpful
3answers
Fisher & Paykel M#DD603SS - While not running F1 repair mssg
Actually the part is called a Link Actuator. There is one for the upper drawer and one for the lower. When the drawer is shut, it will actuate and the dishwasher will lift the drawer up against the upper lid. When the actuator is broken, this will trigger the flood switch which inturn triggers the F1 code. In the meantime, when the dishwasher is turned on, the water will shoot over the side walls of the drawer and get down below to damage the terminal block module.
I have a fisher&paykel dd603ss the lock symbol on the top drawer
If it is beeping "F-1" this is a flood condition usually caused by the lid (s) not sealing. You would need to replace the link supports and possibly the mains filter board. Try unplugging it and letting it dry out for a day or so.
1helpful
Dd603ss c?tting power
"If your not a technician etc this could be a dangerous and tricky job" Ok you need to replace the RFI module (lower PCB/flood sensor) there could also be a fault with one motor controller module you'd need to unplug one drawer at a time then turn on to see which ones faulty. Then you'd also need to stop the leak? repalce the lid actuators, Link supports and the lid if seal is damaged. cheers
2answers
RE: Fischer paykal F1 code
F1 fault means the flood switch on the base of the dishwashers has been activated.
nine times out of ten its the lid motors.
You can remove the two kick plates on the bottom of the dishwasher.
Dry out the water in the base with a sponge.
only one draw will be leaking water??
This allows you to use the second draw until a serviceman shows up.
Dry the base out A.S.A.P, because you have a electronic board that sits on the base. cheers
20helpful
6answers
Fisher and paykel DD-603 dish drawer
Hi there, If you have had an F1 you need to dry out the product in order to reset the flood switch. This is a simple process as follows: 1. Ensure product is disconnect from wall so that it has no power. 2. Open the bottom drawer and put your hand in through the gap where the bottom of the bottom drawer comes out and feel the base of the cabinet that houses the drawers for water. 3. If there is water present dry it out as much as you can with paper towels or old rags. This machine is designed to drain all water to the front of the base of the cabinet away from the flood switch that sits at the back left corner of the cabinet base that the drawers are fitted into. 4. When you have base of the cabinet dry you need to ensure that the switch has not moisture on it in order for it to reset and allow you to start using the product. This can be done 2 ways: 1. leave bottom drawer open for 24-48 hours to allow natural air circulation to dry out the connection. or 2. position a hair dryer to blow air into the back left corner of the base of the cabinet and dry it out quicker. This still make take up to 6 hours as the flood switch had a protective cover over it to try to prevent F1's for small spills. 5. When the product had been dried out, important that you make sure it has, when you switch on the machine the F1 should be gone and ready to use. Please run each drawer seperately on a rinse cycle to confirm to yourself that it flooding was possibly caused by something blocking the sprayarm, or something stacked too high or something got stuck in the pump temporarily stopping it from draining effectively or the product suddsing too much from spilt rinse aide in one of the drawers. If each drawer runs successfully you should be in the all clear to start using it again. Please note though: if something blocks the spray arm that is directly linked to the pump your drawer will flood as a result. If you have something stuck in the pump peventing it from draining effectively ie a toothpick or piece of broken crockery this will cause your product to flood, but you will hear an louder than normal sound when the pump is running. And finally if you spill rinse aide in your drawer when filling it clean all spilt rinse aide to prevent unit from over sudsing when running. Regards KAR-Ltd
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Marvin
Marvin
Paul Bade
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
