Question about GE Profile PGSS5PJXSS Stainless Steel Bottom Freezer French Door Refrigerator
Ge profile french door refrigerator leaking water onto the floor
My ge profile french door refrigerator is leaking water onto the floor. happens once or twice a day. Running down the front legs, and appears to be running out the front of the freezer cabinet. In the freezer cabinet, the water appears to be coming down the back wall in the center. It pools up in the freezer floor... but then occasionally seems to run all the way through and out the front.
Anonymous
SOURCE:
appldoctom
Thomas Malailua
  • 311 Answers
SOURCE: water leaks out of freezer once or twice per day
is there water frozen on the frezer floor.if yes your defrost drain is froze over.it only happens a few times a day because happening when its going into defrost,the water melts on the frezer evaporater then should go in the drain.if blocked it then runs on floor.you could turn of your refer for 8 hours or so.or get to the bottom of frezer behind back frezer panel[remove]and use a hair dryer to thaw drain use a weed eater line with a knott on an end to push thru and pull out the other side.the knott would clean any stuff in the drain line.ps watch out for water and electricty.i hope this helps God bless,tom
Posted on Jan 15, 2009
Maytag317
Victor
  • 1136 Answers
SOURCE: water from GE Profile Refrig/freezer drips down
Hi, Is it bypassing the drain or is the drain plugged? The most common is that the drain hole gets iced up and them overflows onto the floor.
Just wanting clarifcation.
Posted on Jul 12, 2009
woodchuck789
Charles T Nevin
  • 4070 Answers
SOURCE: GE side by side leaks water from icemaker tube
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Aug 17, 2009
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: Once a day my refrigerator has water that comes
This is caused by a defrost Drain Blockage. Click here=> Sea Breeze Tip's
Hope this helps, Thanks, Sea Breeze
Posted on Sep 26, 2010
pblju
perry d
  • 32 Answers
SOURCE: Water in the bottom freezer of a 2000 GE Profile refrigerator
look in bottom at back for drain hole, may be clogged, or even hole frozen over with collected water. Clear the drain hole.
Posted on Jul 30, 2012
GE Profile PFSS6PKXCSS leaks under crisper
i have a ge thats doing the same thing ine has a live running on back dont know if i unhook on back or tahe off control box hey go 2 http://www.partselect.com/ they have diagras and a help solution page let e know when u find solution
Dec 29, 2012 | GE Refrigerators
Water is leaking out from the bottom of the freezer
Below the freezer coil is a drain trough. Sounds like it is frozen. Use a hair drier to melt it and poor baking soda with warm water down it.
Jun 02, 2010 | GE Profile PSS26NGS Side by Side...
Ice builds up on bottom of freezer and water runs out onto floor.
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
May 31, 2010 | GE Profile PFS22SBSS Bottom Freezer French...
GE Profile leaking onto floor
Clean the drain pan and drain line in the back of the freezer section behind the cover underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Apr 19, 2010 | GE Profile TPX24PBDCC Side by Side...
Once or twice per day, water on floor below freezer door
check for plugged drain at back bottom of freezer if plugged/frozen over defrost and clear with hot water and remove all ice.
Nov 13, 2009 | Admiral 26 cu. ft. Side-By-Side...
Water comes from under drawers on fridge side, leaks onto floor
If leak continued then you must have a faulty cut off valve. Check and tighten valve. Also, check the hose that runs underneath the fridge for cuts or holes.
Jul 12, 2009 | GE Profile PFS22 33" Artica French Door...
Defrost line blocked and dumps water in front of frig once a day
Double door Maytag. Water frozen in the bottom and leaking onto the floor. Happened before and don't wish to pay the same repair person who "repaired" it 6 months ago to come out again. What can I do?
Jun 09, 2009 | Maytag MSD2756G Side by Side Refrigerator
Water leaks out of freezer once or twice per day
Jan 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile PGSS5PJXSS Stainless Steel Bottom Freezer French Door Refrigerator Logo
590 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Ron Beer
Ron Beer
Level 1 Expert
Vish Iyer
Vish Iyer
