Question about Rowenta Professional DE880 Iron
Spray broken, can't figure how to take apart to check
Iron fell on the floor and broke part of the spray nozzle, also steam lever that moves from side to side is very loose, like something under it is broken. Cannot figure how to take the top of the handle off so I can check it out. Any suggestions
Posted by mrchan on
Anonymous
  • 24 Answers
You've to open the unscrew the rear screw and take out the rear cover.It's quite hard to fix it if you don't have the schematic diagram. Suggest you odd to have the iron schematic to have step by step as for your easy guide reference.
Rdgs
alan
Posted on Feb 27, 2008
Tefal repairs
follow this steps and fix it. God bless you
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in wat
Nov 29, 2013 | Irons
The green light does not come on and it does not steam
follow this adjustment and fix it. God bless you
Clean an iron:
  1. Unplug the iron.
Nov 04, 2013 | Oreck Steam-It Steam Wand
Does red light suppose to flash
follow this section troubleshooting and fix it. God bless you
Clean an iron:
  1. Unplug the iron.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Oct 15, 2013 | Rowenta Effective DX1900 Iron with Auto...
Model gh3000 spool will not release for removal
Clean an iron:
  1. Unplug the iron.
Oct 09, 2013 | Irons
WATER HOSE PERISH
Clean an iron:
  1. Unplug the iron.
Clean a metal soleplate:
  1. Unplug the iron.
  2. Use a sponge and commercial soleplate cleaner or baking soda and water to remove dirt buildup on the soleplate. Rinse well with water and dry. Don't use harsh abrasives or immerse an electric iron in water.
  3. Use very fine steel wool (0000) or an emery cloth to remove scratches and burns on the soleplate, then clean the soleplate.
Oct 01, 2013 | Irons
Floor steamer not getting hot
GOD BLESS YOU
Clean an iron:
  1. Unplug the iron.
  1. Unplug the iron.
Sep 30, 2013 | Conair Compact Garment Steamer Iron
How to open a steam iron severin
follow this principle.God bless you
Clean an iron:
  1. Unplug the iron.
  1. Unplug the iron.
Jul 20, 2013 | Severin Steam Iron, 2500 Watt, White...
Pump wont run
Clean an iron:
  1. Unplug the iron.
  4. God bless you
Apr 04, 2013 | Rowenta DG-980 Iron
The steam button is stuck on (pushed in) but there's no steam.
follow this steps. God bless you
Clean an iron:
  1. Unplug the iron.
  1. Unplug the iron.
Nov 15, 2012 | Black & Decker Irons
Steam gauge is broken and iron will not produce steam
http://www.fixitclub.com/Parts_Components/Appliance_Controls.shtml click the link  Maintenance and repair tools you'll need to fix an electric iron include these:
  • Screwdrivers
  • Toothpicks or pipe cleaners
  • Sewing needle
  • Commercial electric iron cleaning solution or vinegar and water
  • Commercial soleplate cleaner or baking soda and water
  • Steel wool
  • Emery cloth
  • Metal cooking pot
you will need a speacial tool screw driver  also called as g5 screw driver to open it.available at local repair store. If the iron doesn't heat, make sure power is on to the outlet, check the electrical cord, and check the thermostat (see the Appliance Controls Fix-It Guide) and replace if necessary.
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat (see the Appliance Controls Fix-It Guide).
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Mar 26, 2009 | Rowenta Irons
Rowenta Professional DE880 Iron Logo
241 people viewed this question
Top Rowenta Irons Experts
Ekse
Bruce Showalter
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
